Results 1 to 10 of 13
    Apr 2014
    Owensboro, KY
    Default Depth Finder Transducer
    What expoxy are you guys using? Mine is showing --- while underway so I am assuming the expoxy has gone bad?
    Thanks,
    Jul 2013
    Cedar Falls, IA
    Mine is doing this from time to time as well... Usually just power down and power up and it works... Guess I ought to see how well it's attached.
    2013 Moomba Mojo 2.5
    Exile SXT9's, Xi12D, Javelin, 800.4, ZLD MKII
    SUMO 900's in rear, 650 IBS and FLOW
    2012 Ford F150 Ecoboost
    Eugene OR
    I am having the same issue but have not looked into it yet. There is another Thread on this subject.
    https://forum.moomba.com/showthread....unting-In-Hull
    Sep 2013
    Bennett, N.C.
    Mine started that and a friends did it this year had to replace the depth finder I think the factory ones are known for this.
    2004 Mobius LSV 340 HP
    Gravity III Ballast
    750s in Rear
    Stock 400 in Front
    Jul 2013
    North Mississippi
    I'm getting the occasional "----" as well. I didn't realize the factory ones are known for this. Do I only need to replace the transducer? Is it plug and play with current gauge and wiring?
    2008 Mobius LSV
    1100#er's in the lockers
    ski locker sac
    IBS
    Johnson reversibles
    May 2013
    Vancouver WA
    are yours thru hull or in hull? Mine is in hull (no cut) and I have to fill mine with mineral oil. I think I must have a small leak somewhere that is allowing the oil to seep out, as I'll get --- or some whack readings and once I top off the mineral oil it works great.
    Mine was doing all kind of crazy things... giving the "---" and first of the year didn't even work. I ended looking, and the transducer was coming un glued. For the life of me i can't remember what i had used to glue it back down. It was an epoxy that was good to use in Marine environment. I reglued after our session before putting boat away, the next week it didn't work, then the following week, everything seems to be working fine.. but hey its working!
    B.J. Reed
    2006 Moomba OBV
    Jul 2013
    North Mississippi
    Hmm...I'll have to give mine a look see. Hopefully that's all it is.
    2008 Mobius LSV
    ski locker sac
    IBS
    Johnson reversibles
    Couple years ago I bought a new one only to find my old one had just broken loose and was rattling around in the bilge. Used this stuff to mount the new one - http://www.homedepot.com/p/Loctite-0...5604/100371825
    In hindsight I probably shouldn't have done that but it hasn't budged since I mounted the "new" transducer. You need to twist it back and forth when applying to get all air bubbles out if I recall.
    I'd really like to upgrade to one of the thru-hull eye Faria ones that can give both air and water temp as well instead of the glued in-hull style. Mine works 80% of the time. The 20% it flashes --- is usually when I'm coming into some unfamiliar cove or beach.
    Jul 2013
    North Mississippi
    Ya, mine seems to be in the 80% / 20% club (or maybe 60/40). And of course the --- usually appears at the least opportune time...
    So, is a thru hull better than one that's appoxied to the hull?
    2008 Mobius LSV
    ski locker sac
    IBS
    Johnson reversibles
