Results 1 to 3 of 3
Thread: electrical problem
06-02-2014, 12:47 PM #1Junior Member
- Sep 2013
- 10
electrical problem
i have a electrical problem with my 2006 moomba xlv the switch,fuel gauge, temp gauge and radio dont works. I know after verify the power (12v) arrived at the gauges and switch . i supposed the problem is a ground problem but i dont know where is the ground . i want to know where is the ground for this accessory for resolve my problem . anybody have a wiring diagram or info for this problem?
06-02-2014, 03:37 PM #2
Generally under the dash is a ground block. There is also a power block where all wires meet for a common power and ground then a larger 8 gauge wire rubs to the batteries to tie into the respective power points.
Your gauges also require a source of the ignition switch so check for loose connections there.Malo <--- Means--Evil or Mean One. This explains a lot.
[COLOR="#696969"]
06-18-2014, 11:44 AM #3Junior Member
- Aug 2013
- 1
