Results 1 to 9 of 9
    Irondequoit Bay, NY
    Default what do you think..
    of my new custom Strut? haha..once i poped her off the shaft went back to her original position
    Rockford fasgate cabins
    Exile XM7's
    Exile Harpoon
    Exile ZLD
    Polk 10in sub (2)
    Polk P330 amp (subs)
    Got some swerve in that bugga.
    Jul 2012
    Cumming Ga
    Do you think it also bent the shaft a little.
    Irondequoit Bay, NY
    it didnt look like that after i popped it off..it lined right up with the rudder and i checked the gap where the shaft came out of the boat and it was ( from what i can tell) about equal all the way around
    Exile XM7's
    Exile Harpoon
    Exile ZLD
    Polk 10in sub (2)
    Irondequoit Bay, NY
    there looks to be a brass sleeve in the strut..is that part of the rubber seal in there? when i replace the seal do i have to get that sleeve out as well?
    Exile XM7's
    Exile Harpoon
    Exile ZLD
    Polk 10in sub (2)
    Aug 2011
    Commerce Lake, MI
    That's a bushing that acts as a bearing. you can't replace it. These are sealed they use water as the hydrodyamic lubricant in the bushing like a plain bearing.
    2017 Moomba Craz
    Irondequoit Bay, NY
    But can replace that bushing? I have seen some for sale. I ask because if I can't replace it, then I might as well get a new strut and not try and save me 500$ on a new one
    Exile XM7's
    Exile Harpoon
    Exile ZLD
    Polk 10in sub (2)
    Mar 2012
    Spring, Texas
    You can get the bushing out and replace
    Wetsounds Rev 10's
    XS-650's
    Syn 6
    Syn 4
    WS-420
    Irondequoit Bay, NY
    we got her a straight as we could for now..thinking if i should try some more or not. i think worse case ill be buying bushings more often
    Exile XM7's
    Exile Harpoon
    Exile ZLD
    Polk 10in sub (2)
