Results 1 to 10 of 11
Thread: Prop/Shaft Damage?
04-03-2006, 10:11 AM #1
Prop/Shaft Damage?
During out last outing a buddy of mine ran over my rope. It is wrapped tightly around the shaft behind the propeller. I had the boat towed in because I was unable to get it off while in the water. I dove for an hour..in 42 degree water...and had to give up..
I have not taken the propeller off yet...hopefully tonight. I do not have a puller (I noticed Ben624's post) hopefully this can be done without one. When I get it off, should I look for anything else? Has this happened to anyone here? Was there other damage done?
Thank you!
Nate
04-03-2006, 10:20 AM #2Senior Member
- Dec 2005
- Ontario
- 531
Replying to Topic 'Prop/Shaft Damage?'
Wait until you run over your first spectra line!!
Oh what a feeling!!
Dont sweat it, comes with the territory... happens to us all sooner or later2005 Moomba Outback
04-03-2006, 10:30 AM #3Senior Member
- Feb 2006
- Fayetteville, GA
- 319
Oh what a feeling!!
Ditto on the sharp knife.
04-03-2006, 11:04 AM #4
We tried using a knife. The rope I ran over is the Accurate 80 ft A-Line. It has that Urethane Cable coating over the line. Makes it pretty durable. The rope is already trashed....maybe I will get a razor blade and go after it tonight. Might be a little easier now that it is on the trailer.
Wolf - I just went through that.. With shipping - the new one came to about 130. She didnt understand....but - I explained to her that it's like shoes. You can't get the cheap ones!
04-03-2006, 11:12 AM #5Senior Member
- Feb 2006
- Fayetteville, GA
- 319
04-03-2006, 11:27 AM #6Senior Member
- Dec 2005
- Ontario
- 531
Yep my wife didnt understand either.. My first really good rope was an 80 ft hardline cost the wife 150.00 She thought that was pretty dumb. Man did I feel bad when the 3rd time out I had to tell her that I had to go get a new one.
Of course one of my buddies took the blame for it...Way to take one for the team!!
If you have trouble with the knife a pair of wire cutting pliers works really well2005 Moomba Outback
04-03-2006, 11:40 AM #7Senior Member
- Mar 2005
- t-town
- 718
It has happened to me twice. Once my fault and second there was about 15ft of rope under the water. I was pulling my son and all sudden the boat just stopped under thottle. Well it turns out the rope caught around the shaft and prop.
No damage but a little diving took care of it. I learned a diving mask, knive and 10 ft of plastic tubbing make the job much easier.
I don't think I could have cut it off in that much water.
04-03-2006, 01:39 PM #8Senior Member
- Dec 2005
- Ontario
- 531
what was the plastic tubing for??
2005 Moomba Outback
04-03-2006, 01:44 PM #9Senior Member
- Mar 2005
- t-town
- 718
smartz, a make shift snorkle. that way you don't have to keep going under and then back up for a breath. saves you a lot of time.
04-03-2006, 03:06 PM #10
qb12,
I like the tube idea.....that would have been great. Every time I dove under the boat and was able to unravel the rope once - I had to come back up for air. A mask would have been very helpfull also.
Being that the water was only 42 degrees....it may not have made that much of a difference.
Once is enough...I hope it doesnt happen again. I will probably have to buy her something nice next time.....LOL
Prop shaft mount
By tkderose in forum General ChatReplies: 10Last Post: 04-25-2008, 10:29 AM -
Bent prop, strut and shaft
By Rugburn in forum Service & RepairReplies: 14Last Post: 07-29-2006, 11:41 AM -
Rudder / Prop damage...please help!
By pss3757 in forum Service & RepairReplies: 3Last Post: 07-09-2006, 08:55 PM -
Prop Shaft Alignment help....
By JesseC in forum Service & RepairReplies: 4Last Post: 05-22-2006, 09:10 PM -
Noise from prop/shaft
By Livindadream in forum Service & RepairReplies: 9Last Post: 09-09-2005, 04:37 PM
