Page 3 of 3 FirstFirst 123
Results 21 to 28 of 28
  1. #21
    Nov 2013
    West of ATL
    I'm guessing this is the Crank Position Sensor? Found it located on the front/port side of the block behind what I'm guessing is the Harmonic Balancer.
    Also would a bad sensor cause a crank and hard to start scenario but still allow the engine to run fine and smooth once started?
    2008 LSV on the way out
    '17 CRAZ!!! on the way in
  2. #22
    Jul 2011
    Rockwood,TN
    Default 08 lsv hard to start!
    Yes that's it. Yes it could not always the case but a possibility.
  3. #23
    May 2010
    Salt Lake City, Utah
    I'm sure this isn't it but make sure nothing is touching the kill switch at all. I found out the hard way that those kill switches are incredibly sensitive. I had a hat bump it every now and then and the engine would stall. I just jumped the wires to it together and took the kill switch out of play. Good luck . Let us know what you find.
    Scott
    2007 Mobius LSV with a lot of great upgrades and mods
  4. #24
    Jul 2011
    Rockwood,TN
    Ok just left the dealer... Hooked up to the computer I was getting map sensor fault but the technician said he has seen a bunch of ignition switches go bad in these. So we looked at voltage on his computer and sure enough it had 12volts until you started to turn the engine over and it fell to 0. Sure enough we plugged a new switch in and it starts right up. The switch was like $30 or so.
  5. #25
    May 2010
    That is great. I love it when it is a cheap fix, although you ended up doing a lot of other things.
    Scott
  6. #26
    Jul 2011
    Rockwood,TN
    I know me too! And thank you and everybody else on this great forum for your help! I'm thinking about removing my kill switch too for that reason.. What if anything did you put in its place?
  7. #27
    Jul 2013
    North Mississippi
    Thanks a lot for posting a follow up with the fix. That's one more piece of info we can all add to our trouble shooting library. Nice cheap fix too.
    2008 Mobius LSV
    1100#er's in the lockers
    ski locker sac
    IBS
    Johnson reversibles
  8. #28
    May 2010
    Quote Originally Posted by 23scuba View Post
    I left the switch in place and just disconnected the wires from the switch behind it and connect them together.
    Scott
