Results 1 to 10 of 14
    Default 2008 moomba lsv no start
    5.7 l indmar I have got good spark I have fuel all the way to the rail yet the plugs are dry and won't fire could the fuel pressure be to low? I can't think of anything else please help !!!
    Jun 2009
    South West Colorado
    It might be worth popping the injectors off to see if they are gummed up and if you get the fuel pressure relief.
    '08 Mobius LSV, Mods- 1100 lb Rear Sacs, IBS Sac, Center 400 Sac, Dedicated thru-hull intakes and pumps per sac, SeaDek One Piece Mica over Black Roo, EZ Net Cargo Nets, Swivel Drivers Seat, Hot Water Shower, Hinged Wind Block, Bow Cushion Adapter Plate for Drink Holders Access, etc, etc.
    Very possible your fuel pressure is to low. Last year on my Vette I had pressure at the rail but it wouldn't start. Replaced fuel pump it fired right up.
    get a test light and make sure your injectors have power, ground the test light and test both wires to the injectors, if one of them should cause the light to flash. also check the actual fuel pressure, you can rent a fuel pressure gauge from a local auto parts store for cheap. should be around 40-50 psi i would think.
    Nov 2003
    Land O Lakes, Florida
    um, is the kill cord connected properly. just don't ask why im asking
    Hey, Its Moomba time
    13 Mobius LSV-sold
    08 Mobius LSV-sold
    03 Mobius LSV-sold
    May 2012
    Louisville ky
    Try the oil pressure safety switch haveing same problem with my xlv 5.7. Done everything, my last resort is this oil pressure safety switch. It has there wires one of supposedly relay to the motor that the oils pressure is up so the fuel pump will kick in. I dunno trying today my weekend was already ruined and not to mention I spent 500$ at a shop and it still doesn't work.
    Apr 2014
    Roanke, VA
    X2 on the oil pressure switch
    Yellow over White 99 Mobius 21'open on jet black double axle
    Mar 2014
    Park City, Utah
    In Neutral? Even if it looks like it is it may not be, put it in gear and back out. Yes, I learned this the hard way!
    2013 Supra SA450 with da FLOW
    2006 Mobius LSV - Sold
    2004 Stingray 190LS - Sold
    www.tffor.org
    Mar 2012
    Richmond, VA
    X3 on the oil pressure switch. I had this problem a couple of years ago.
    2014 MOJO 345 Surf
    2005 Mobius LSV, carb - Sold
    Nov 2013
    West of ATL
    I'm curious. I also have issues starting my 08 LSV in the morning it can take 10 to 15 turns of the key to finally get the engine running. After running for a while in order to restart I find that if I turn the key, hear the fuel pump kick in, and try to start it won't. But I'll the push the throttle forward to kill the starter while holding the key in the start position then bump the throttle back to neutral it will start but I have to throw the throttle froward a little to keep it running.
    Could I have a problem with the oil pressure switch. It reads normal oil pressure while running and I put about 15hrs on the boat over the long weekend and it ran fine.
    2008 LSV on the way out
    '17 CRAZ!!! on the way in
