Results 21 to 30 of 37
05-22-2014, 07:37 AM #21Senior Member
- Aug 2008
- Hilliard, Ohio
- 794
My wires might have melted since we had to run boat back to slip. the issue is inside the transducer that starts drawing over voltage. it is only Thursday they might be able to overnight on out have an install Friday just in time for the weekend
05-22-2014, 09:18 AM #22Senior Member
- May 2012
- Jamestown Ky, Lake Cumberland/Dale Hollow
- 121
So if I unplug it if this happens, It will run fine.. I just wont have gauges?
1995 Moomba Boomerang-SOLD
2008 Moomba Outback DD- SOLD
2014 Moomba Mondo-SOLD
2016 Moomba Craz
05-22-2014, 09:33 AM #23Member
- Jul 2013
- De Pere, WI
- 51
Yes, mine ran fine after I unplugged it. I did have to go under the dash and reset the ignition breaker. My digital display does have a funny distortion to it now (can't remember it being there before).
2014 Moomba Mondo
Indmar 409
900 Sumo's
750 IBS
Wetsounds Three-some w/SD6
05-22-2014, 10:07 AM #24Senior Member
- May 2012
- 121
Called my dealer a few minutes ago. They got a list yesterday of all the boats that might be affected by this problem. Mine was not included in the recall on these parts. Vin number specific. Call your dealers they should know if your on the recall!
2016 Moomba Craz
05-22-2014, 10:08 AM #25Senior Member
- Aug 2008
- Hilliard, Ohio
- 794
Yes, once unplugged it runs fine. No speedo or temp
05-22-2014, 10:24 AM #26Member
- Jun 2013
- Huntsville, AL
- 85
I just received my service bulletin today. I will be contacted when the parts arrive.
1991 Cobia Monte Carlo 188E (Sold)
2014 Moomba Mojo (Sold)
Next ??
05-22-2014, 11:44 AM #27
05-22-2014, 12:24 PM #28Member
- Jun 2013
- Huntsville, AL
- 85
5/20/2014
Please note this is a SERVICE BULLETIN and compliance is mandatory
2014 Moomba Speedometer Paddlewheel
Boats effected:
2014 model year Moomba boats manufactured between October 2013 and March 2014. Serial numbers
ending in; J314, K314, L314, A414, B414, C414.
Issue:
The paddlewheel circuit board may be damaged by a voltage spike the ECM can produce and may trip
the engine ignition circuit breaker within the first few hours of operation.
Symptoms:
When the paddlewheel fails it can produce one or more of the following symptoms;
o No speed reading on the dash
o Engine breaker under the dash trips
o Engine shuts down
o Electrical smell in engine well
In order to get the engine running to return the boat, unplug the speedometer pigtail from the harness
located under the transmission cover (Image A) and reset the breaker under the dash. This will allow
the engine to safely restart.
Solution:
Replace the paddlewheel with a newer unit that now has an overvoltage protection chip on the
paddlewheel circuit board within the unit. Skier’s Choice Part number 104634 looks the same as the
original paddlewheel. The overvoltage protected paddlewheel has a manufacture date of 3/14 or
greater on the label affixed to the wiring pigtail (Image B).
Image A Image B
Service Bulletin1991 Cobia Monte Carlo 188E (Sold)
Next ??
05-22-2014, 01:19 PM #29
Thanks Samvg1,
Mine is affected (C414), just lost the speed reading, no other symptoms.
05-22-2014, 03:54 PM #30
