    Default 2009 Mobius lsv prop upgrade
    Can someone reccomend me a prop to get out of the hole a little faster? Mine has a slight dent in it and has a little vibration. Its the stock prop that came on it. I have a indmar 325. I've read some stuff on acme 1433 or acme 1235
    2009 moomba Mobius lsv
    Might want to add your location (elevation is relevant) and how much ballast you run and what activities you like to do. I don't run very much ballast and we ski, wakeboard and surf. I run a tweener prop like the 1161 or 537. It's about the best crossover one if you need ski speed and don't run more than 2000 at sea level. If you are like some of these guys you may need something much different.
    Take a look at this thread for some good discussion:
    https://forum.moomba.com/showthread....3-vs-Acme-1161
    Jul 2011
    SE MI
    I run the acme 1847 and have been really happy with it...
    2008 LSV 1100s 650IBS Reversible Pumps w\Timers
    Default Re: 2009 Mobius lsv prop upgrade
    I had the 1847 and have the 1433, both are great. The 1433 will kill your top end speed/fuel consumption if that's important.. If you run a lot of ballast and don't need speed or travel long distance then the 1433, else the 1847..
    2006 Moomba Mobius LSV - Sold
    colorado
    I had the OJ wakeboard prop but changed to an ACME xxxx a few years ago. I really like the change, much quieter, better hole, shot. I usually have 500 in the rear lockers and 400 in the front. dropped my top speed down to about 37-38. I'm in Denver CO and usual elevation is 5600' occasionally run at 7-8000, and lake powell at 3600.
    19 Mondo
    08 LSV, forever loved
    1847 if you surf with weight or are at elevation. I've used it with 3000+ in the boat at Lake Tahoe (6200 elevation) and had no problems. It does cut 5-7 mph off the top end.
    DDNorCal
    2019 Supra 450 SL, 1,000 lb lead and 3145 prop
    Sold - 2006 LSV 3430 Ballast, 1847 Prop, all around great boat
    Salt Lake City, Utah
    Call wake makers, they are great and will hook you up with what you need.
    Scott
    2021 Craz
    1997 Sea Ray 190
