Results 1 to 10 of 17
    Jul 2013
    Windsor ON
    Default Exile xm9's advise and help
    I recently purchased a pair of xm9's to replace my current tower speakers. Pretty excited with all that I have read about these speakers so far.
    What some of my questions are;
    1) will the current amp I have be adequate to power them. I have a rockford fosgate m600-4d.
    2) if I wanted to add another pair, would the sxt9q compliment the sound or would it be better to get another set of the xm9's? And if I did add another pair, I know I would need another amp. What would be the amp to add? Would I get rid of the RF I currently have and buy one to run both sets?
    Quote Originally Posted by liquid_acid View Post
    For me personally If i was to upgrade to 4 XM9 I would go with the Exile 30.2 its designed to run 4 XM9s.
    On your current set up as long as you bridge those 4 channels together into 2 you should be making 300 per channel and thats fine.
    When considering to buy another set of speakers I would go XM9 all the way. The old school of thought with mixing the XM series and SX series was due to the XM7 line. The HLCD XM7 was very vocal and not a lot of warmth due to speaker cone size. The SXT series had a lager mid bass speaker due to the tweeters being separate. With both styles you got a much better sound.
    With the XM9 series I personally would not mix them. The XM9 has a great sound and the SXT also has a great sound but I don't think you gain any benefits truly by mixing them like we did with XM7 series
    Question. Do you need 4 ? I have 4 and they sound great , but at times it is really overkill, sometimes I am "that guy " on our lake . Lol
    Mike is correct the exile 30.2 will do the job great, you may be able to grab a harpoon demo for a deal, which is great too.
    Mike has 6 and definately Is "THAT Boat" on the lake .
    Tooele UT....
    Mike has 6 and definately Is "THAT PARTY COVE" on the lake .
    jm, fify. with his setup, he's a complete mobile rock show on the water .......
    Jul 2013
    Windsor ON
    I suppose I don't "need" 4. I can sometimes be "that guy" tho. Lol.
    I haven't even heard these speakers yet so I'm not quite sure what I'm in for. The main reason I went with exile is because you couldn't hear the tunes very well over the motor when wakeboarding with the ones I currently have. Also I go to this island quite a bit and park with the bow on the beach. Nice feature to spin the speakers around facing you.
    Jan 2010
    North Texas
    I've been very pleased with our 30.2s also. Would be great for the 4 of them.
    Sent from my SAMSUNG-SM-G870A using Tapatalk
    2006 Supra 20 - Sold
    2015 Supra SE450
    Oct 2009
    Pacific NW USA
    Mr Liquid -
    If you haven't heard the XM9s yet on your boat, I suggest you use the RFamplifier you have currently. Chances are you are going to get stoked and want a second pair. Most people usually do.. If fills up your tower, and it gives you the ability to "be that guy" when you want to be. when you take the plunge for a second set, I also agree with what Mike said in that you should go with a second set of XM9's over the SXT9's. I'd power them with the XM30.2 like the guys have mentioned. It makes for easy setup because the crossover on that amplifier starts at 80hz (which exactly what you want for XM9's).
    But in short - start with what you got, and be your own critic. Maybe 1 pair is all that you need
    -Brian
    PS: Dusty you sell your boat yet? I been meaning to ask!
    I agree that your current rockford amp in 2 chnl bridge mode @ 300W rms is a good spot for most any 8" HLCD. Subtract a little wattage from its rated 14.4 voltage to a more realistic 13.5 and you still have some good headroom wattage wise. With a little more reduction in power when at engine off 12.5, you are still driving them with solid power well over 200W.
    If you later decide a 2nd pair is wanted, swapping out to a 2 chnl is ideal, but you could also install a 2nd matching rockford.
    There should be no need to mix an HLCD like the xm9 with a traditional coaxial like the sxt to improve sound quality. If tonal control is needed in order to attenuate the compression driver, a dual zone EQ will allow you to adjust the tower speaker to suite, without effecting the in-boats. The only other efficient way to get better sound quality, is to simply go with a larger HLCD.
    Jul 2013
    Windsor ON
    I really appreciate everyone's help and advice.
    Sounds like I might get another set of xm9's and another amp down the road.
    I am currently working with a ws420sq eq.
    So if I buy another pair of xm9's I should get a 30.2s to run just those 2 speakers? And keep the ones I have now running off the Rockford Fostgate?
    Vicksburg, MI
    No, run all 4 on the 30.2
    Joe
    2014 LSV
    2010 Outback V - Sold
    1993 Echelon
