Results 1 to 10 of 17
Thread: IBS not Filling
    Nov 2009
    Nebraska
    Default IBS not Filling
    I piggybacked my center bag to my IBS this weekend. I can't get any water into my IBS though. It seems like water will run through, but not enough to fill it consistently.
    2016 Mojo
    2010 Moomba LSV-Sold
    Do you have the IBS vented?
    I assume you have Jabsco style pumps? Did you increase the Run time on your switches?
    Nov 2009
    Nebraska
    Yep it is vented through a T that goes to the thru hull vent. I have not increase the run time.
    2016 Mojo
    The pump timer was set to only fill the center. You have to increase time upon the timer so the pump continues to run & fill the IBS.
    2016 Supra SA 450
    2015 Supra SG 450
    2012 Moomba Mojo
    2008 Moomba OBV
    Nov 2009
    Nebraska
    It won't work if I just shut it off and turn it back on
    2016 Mojo
    Only if you want to cycle it back on about 8 times. And, you will have to do the same when emptying.
    2016 Supra SA 450
    2015 Supra SG 450
    2012 Moomba Mojo
    2008 Moomba OBV
    Nov 2009
    Nebraska
    How long does it take to fill both from that one pump?
    2016 Mojo
    Nov 2009
    Nebraska
    Here's how spencer drew it out for me
    2016 Mojo
    Aug 2013
    DFW
    Quote Originally Posted by snyderaaron View Post
    In this drawing, what happens when one bag fills before the other? Looks like if the center bag where to fill first, it would start venting before the IBS would be full.
    Matt
    2016 Mojo
    2012 LSV (sold)
    Nov 2009
    Nebraska
    Do I need the bosworth valve
    2016 Mojo
