    Jul 2011
    Rockwood,TN
    Default Can anyone help me identify these bag weights?
    These are filled with air... The one on the right I bought from a guy who said they were 750lbs the one on the left was in my 2008 lsv but I'm not sure if it's stock or not.. Can anybody tell by just looking at them?
    If you post their measurements then we could tell you how much weight they hold.
    Mike
    - FAE
    - DIY suckgate
    Jul 2011
    Rockwood,TN
    Ok I'll get them when I get home today... Thanks
    Vicksburg, MI
    The 750 should be 20" X 20" X 50"
    Joe
    2014 LSV
    2010 Outback V - Sold
    1993 Echelon
    Mar 2012
    South Carolina
    If you have the Gravity III ballast like I do in my Supra, then the one on the left is more than likely 400# as the two rear locker sacs are 400#ers. Very inefficiently long. The one on the right does look like a 750# sac but as mentioned the measurements will help.
    Quote Originally Posted by jstenger View Post
    And I believe the 1100 is 24" x 24" x 50"
    Mike
    - FAE
    - DIY suckgate
    Jul 2011
    Murrieta, CA
    Correct.....
    the serial number should tell you the dimensions post a pic of each one..
    Jul 2011
    Rockwood,TN
    The shorter bag is 16 x 16 x 42-43 roughly if I'm measuring right.... I don't see a serial # on this one anywhere... The taller one is 16 wide 10 tall and about 55 long it has a serial # of 062507102054 I don't see one on the other one... I'm new to this so if my measurements seem off let me know I'll try again. I aired them up with my compressor to measure... Thanks everybody
    Looks like the 16x16x42 is 400lbs and the closest to the other size is 10x16x62 is 370lbs so yours is probably around 300lbs
    Mike
    - FAE
    - DIY suckgate
