Thread: Thermostat
    Sep 2013
    Default Thermostat
    Question on thermostats,
    Removed the thermostat last fall to winterized the boat and now can't figure out if it goes on the intake manifold or between the thermostat housing? It's a 2 piece housing with 3 bolts vortec sticker on the top.lower section has the water intake hoses and top section has the hoses to exhaust manifolds
    Both spots has a notch for a thermostat
    It's a 2004 moomba with a indmar vortec 350
    Any help would be Appreciated
    Adam
    Irondequoit Bay, NY
    mine went under the 3 bolt..i think it it looks kinda like a triangle if i remember
    Rockford fasgate cabins
    Exile XM7's
    Exile Harpoon
    Exile ZLD
    Polk 10in sub (2)
    Polk P330 amp (subs)
    Usually between manifold and housing (on the manifold). Can you see a little recess ring on the manifold for it to sit in?
    Sep 2013
    Yes there is a re
    ssessed rim on the manifold but the upper triangle piece also has one to?
    I want to say that the spacer/splitter is for better hose clearance and angles. Most automotive applications have the thermo right in the manifold.
