Results 11 to 16 of 16
Thread: Ballast filling automatically
05-03-2014, 07:30 AM #11
Never mind. I think this is what you mean. Correct?
2008 LSV on the way out
'17 CRAZ!!! on the way in
05-03-2014, 08:04 PM #12
05-03-2014, 09:13 PM #13
Ok I checked and one of the valves was open. Went back on the water today with the valves closed and water still got into the sacs. They didn't fill up but still got about 20 gallons in them.
And to top things off it looks like the empty pump on the left side is inop. Got water in the sac with what looks like a pain to get it out.2008 LSV on the way out
05-05-2014, 06:13 AM #14Senior Member
- Sep 2005
- Claytor Lake, VA
- 598
Check for a blown fuse on the drain pump. You could try putting some weight on the sack and pushing the water past the pump or just drain it to the bilge. Are all sacks filling or just 1? You could have some trash in the valves as stated earlier. I had an Orbit that started acting up and switched to Irritrol several years ago and have not had any issues since. Ordered them through sprinklerwarehoause.com. Pretty sure it was these.
http://www.sprinklerwarehouse.com/Ir...ir-700b-75.htm2005 Mobius LSV
325 EFI
05-05-2014, 06:38 AM #15
It was just I sac but now all are getting just a little bit of water in them. Could you tell me where the fuse block is for the pumps? I tried searching for the post about how to clean the valves but can up empty.
05-05-2014, 10:14 AM #16Senior Member
- Sep 2005
- Claytor Lake, VA
- 598
Should be a seperate relay and fuse block for ballast under the dash.
2005 Mobius LSV
325 EFI
