Results 1 to 10 of 16
    Nov 2013
    West of ATL
    Default Ballast filling automatically
    Was wondering if someone could me what would cause a Ballast to fill on its own. Was out last weekend and never touched the switches. When I went to trailer the boat I noticed it leaning pretty heavy on the right side. Opened the locker up to store some gear and saw the bag was full.
    Any ideas?
    It was kinda hard to empty too. It would start emptying water at a pretty good rate and then would stop like no water was getting to the pump but had more than enough pressure with the bag being full. I'd turn the switch off then back on again and it would start spitting water out again.
    What year and model boat
    Aug 2013
    Richmond, VA
    Not sure about the filling issue but the emptying thing most likely is your timers were at zero and they only cycle on for about one minute. Of course this is all contingent on you having timers.
    Rusty
    2013 Mojo
    Nov 2013
    West of ATL
    2008 LSV don't know way it didn't show in sig
    2008 LSV on the way out
    '17 CRAZ!!! on the way in
    Jun 2009
    South West Colorado
    What ballast setup do you have? Completely factory g3 or have you done upgrades? We need more info on what is in the system to know what the real issue is to look for.
    '08 Mobius LSV- SOLD!
    2017 Mojo Pro
    2008 would be aerator pumps & sprinkler valves. The sprinkler valve is probably gunked up and stuck open. Take apart the valve & clean. Pretty simple, but search forum for more info, if needed.
    Nov 2013
    West of ATL
    Stock ballast. Thanks for the tip about the valve being stuck open. I'll try and find that and clean it out
    If that doesn't work, do a search on the word "Irritrol" (brand name) before you buy a replacement. Lots of good discussion on better valves and systems.
    Sep 2005
    Claytor Lake, VA
    Make sure the little black override lever on the valve for that sac is in the correct position.
    2005 Mobius LSV
    Nov 2013
    West of ATL
    Where is this valve? On the line going to the sac or by the pump. Thanks
