Results 1 to 9 of 9
    Sep 2013
    Bennett, N.C.
    Default Steam from Exhaust?
    Hey guys need some help took boat out for the first time this year at idle noticed steam from exhaust temp gauge never got above 180.Hoping it's from hot exhaust in cooler water,air temp today was around 80 and water temp mid 60's any idea's?
    2004 Mobius LSV 340 HP
    Gravity III Ballast
    750s in Rear
    Stock 400 in Front
    May 2013
    Physics..........it's normal
    Oct 2013
    Ft. Collins, CO
    Yeah it's normal. It's the same effect that you see in a car's exhaust in cold weather. When the engine is cold, you'll see a pretty constant bit of steam. Then I tend to see it when you power up from an idle. Depending on conditions, you may continue to see a little bit constantly.
    What is your normal operating temp? 180 actually seems a bit warm. Certainly not bad, but usually boats have 160 degree thermostats in them. If someone put an automotive thermostat in there, it would be at about 190.
    1989 Sanger Skier DX - sold
    Sep 2013
    Bennett, N.C.
    Thanks...it usually runs around 175 most of the time.Going to change the impeller just in case we cleaned out the water strainer last week.
    Gravity III Ballast
    750s in Rear
    Stock 400 in Front
    Jan 2009
    Bennett NC
    Was Gary driving? He would make her steam. LOL
    2007 Moomba Outback V
    2015 F-250 PSD CC
    2012 Fuse 40 T-bar
    Sky Ski Le-38
    XXX front wing
    UFO rear wing
    Evo tower
    Sep 2013
    Bennett, N.C.
    He can't drive a real boat!! lol
    Gravity III Ballast
    750s in Rear
    Stock 400 in Front
    Mine always runs just a tad over the 160 mark, I would say 170-175. Don't think anything is wrong with this
    Sent from my iPhone
    Temps are pretty stabil till you reach the 200 mark. Since the cooling system is not a closed system like your car, and you are fresh water you can't go over the 212 or it boils and causes damage.
    The best thing you can do for the boat if it runs hot is IDLE, this will flush the most amount of cool water though the engine and allow the engine to produce the least amount of residual heat from idling.
    Steam is absolutely normal behind a boat when ever the water temp of the lake is less then the engine water temp. you will see it more when the air temp is also low.
    Sep 2013
    Bennett, N.C.
    Well changed the impeller last night...it was chewed up pretty bad and had a lot of small pieces in the J hose.Got lucky this time!
    Gravity III Ballast
    750s in Rear
    Stock 400 in Front
