    Jul 2010
    Vicksburg, MI
    Default Winterizing 345 Surf Motor
    Any quick info on the difference between winterizing the 345 and the 325/330 would be greatly appreciated. My new boat has been in the water, and it is supposed to get below freezing tonight. The indmar manual does not show anything for the 345 motor. I plan on pulling the hoses and plugs. I also plan on putting a shop light in the engine compartment for some heat. Thanks.
    Joe
    2014 LSV
    2010 Outback V - Sold
    1993 Echelon
    It should not be a hard freeze, only reaching freezing temps for a few hours wont hurt, put a shop light in for piece of mind .
    should not be different than the 325 motor.
    Aug 2013
    Richmond, VA
    It is no different just the two plugs on the bottom of the block two plugs at the v drive one on the exhaust and the three hoses on the water pump and the connected hose lines laying across the top of the transmission.
    Rusty
    2013 Mojo
    Yes nothing different. Sounds like you got a good plan already.
