Results 1 to 10 of 11
    Aug 2011
    Default Garage Door Height and 2006 Moomba LSV
    Will a 06 LSV fit under a 83" Door garage door??
    2002 Moomba Mobius LSV - Sold
    2006 Moomba Mobius LSV
    May 2006
    In 06 the OutbackV and LSV shared a hull, right? If so I have no problem clearing a 7' door with 06 OutbackV tower down and a 10' door with the tower up.
    Aug 2011
    Default Re: Garage Door Height and 2006 Moomba LSV
    I think the new outback v is the same hull as my old lsv up to 05, the 06 is larger...
    Jun 2009
    South West Colorado
    06 lsv is larger than obv, no matter which version, same as my 08 lsv. I don't drop my tower to put into garage so I'm no help there.
    '08 Mobius LSV- SOLD!
    2017 Mojo Pro
    Nov 2009
    Nebraska
    That's close. Depends on the pickup and hitch you use
    2016 Mojo
    2010 Moomba LSV-Sold
    Aug 2008
    Hilliard, Ohio
    Yes with a drop hitch
    2006 4X4 Duramax 4" drop
    2009 Chevy 1500 4X4 4" drop
    2013 Suburban 8" drop
    Check out this thread and the links in it to earlier threads. Should have everything you need:
    https://forum.moomba.com/showthread....t=garage+depth
    Aug 2011
    Thanks..
    Aug 2011
    It fit(that's what she said)...
    Pass thru garage?
