04-15-2014, 03:51 PM #1Member
- Jan 2012
- 33
2012 Moomba Mojo Seems to have serious sluggish issues during acceleration.... help
This just started a few weeks ago and I don't know exactly what to think of it. Here is the only way I can describe it...
As I am throttling, it seems that the prop is not engaging with the water.... The RPM goes up and you can hear the engine rev up, but I am not accelerating like I should, I am WAY behind. It is like either the prop shaft is slipping, the prop is slipping, or the gears are slipping. It is the only way to describe the feeling.
I looked at the prop and it needs to be reconditioned thanks to a few bumps and tweaks to it so I am wondering if that bumps are creating too many air bubbles and the prop is not connecting.
I am taking her to the dealer tomorrow but before I do I was wondering if anyone here has had this happen to them and know what it is.
Thanks!!!!
04-15-2014, 05:20 PM #2
maybe from the "bumps and tweaks" you've knocked the key loose and your spinning the prop on the shaft?
04-15-2014, 05:25 PM #3Senior Member
- Aug 2011
- 2,522
The prop is causing cavatation(air bubbles) have it repaired..
2006 Moomba Mobius LSV - Sold
04-15-2014, 06:35 PM #4Member
- Jan 2012
- 33
04-16-2014, 09:33 AM #5
Ouch. I would definitely check my fluid levels in my v-drive and tranny, check coupler bolts to the shaft, inspect the keyway. Shoot, just take it in. (I'd also throw my back up prop on and go for a ride though.)
04-16-2014, 09:43 AM #6
That just doesn't sound right. I'd check transmission fluid, and stop running the boat. until you find something wrong. Other wise you might do some real damage.
Boat had a 2year drive train warranty. Take her in.Malo <--- Means--Evil or Mean One. This explains a lot.
[COLOR="#696969"]
04-16-2014, 02:41 PM #7
Put your spare prop on and see if that makes a difference. I think cavitation.
SOLD
