Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
  1. #11
    Something else to help you out.
    Moomba prop guide http://www.wakemakers.com/moomba-wak...oat-propellers
    Why do they have the OBV listed as a DD boat?
    Honest answer is IDK LOL.
    But they have the LS listed from 04-08 with different props.
    Then the OBV listed from 02-03 and then 06-14
    Maybe it has to do with different HP engines? I really don't have an honest answer lol.
  3. #13
    Aug 2013
    SE PA
    ordered a 543 today
    When stuck inside......
  4. #14
    Jul 2011
    Murrieta, CA
    Default ACME Prop Group Buy? - Any interest?
    The new 2079 arrived today. Tons of clearance between hull and no issues with trailer clearance. Water testing with 4000lbs of ballast tomorrow.
    2010 Moomba XLV
    340hp cat
    Gravity 3, wake plate
    Rad-a-cage
    1100 v-drive lockers
    1180 under the playpen
  5. #15
    Oct 2012
    Greenville, SC
    Got my new acme installed today. Due to boredom and general OCD, I even went through the lapping process with the install. Was surprised to see that without doing it, only had 30-40% contact. After about 20 mins of lapping, was around 90%. Not sure if it really makes a difference, but slid in place nice and locked right in. I've never done it before, but saw another post with a nice tutorial. Also, used a rental puller from autozone which worked like a charm.
  6. #16
    Sugar Land, TX
    What, you can rent a puller from autozone?
    2011 Mobius LSV
    Ron
  7. #17
    Jul 2011
    Murrieta, CA
    Quote Originally Posted by rca View Post
    AutoZone rents tools. My guess is that the puller is a universal style puller.
    2010 Moomba XLV
    340hp cat
    Rad-a-cage
  8. #18
    Whats a lapping process?
  9. #19
    Jul 2011
    Murrieta, CA
    You use lapping compound to show the contact area and file the key until you have a large contact atea
    2010 Moomba XLV
    340hp cat
    Rad-a-cage
  10. #20
    Oct 2012
    Greenville, SC
    http://m.youtube.com/watch?v=2ozh4JjoWm4
    It's a process of fitting the prop to the shaft. Apparently it's a good idea for a tapered shaft like we have. I had never done it before, but was pretty simple and you can get everything from napa for less than $10.
