04-06-2014, 04:05 PM #1Junior Member
- Jan 2012
- 5
Indmar Question-Mechanical System Question
Ok. I am not going to throw anyone under the bus. And please hold an snide comments. I have a 2013 Mojo, 330 HP Indmar. When de-winterizing I instructed the dealership to have my boat lake ready, I am going to pick up the boat and go strait to the lake. Well so when I got underway at the lake motor begins smoking.
Well the dealership did not hook up the coolant system. I did not discover that until I had driven the boat about 1 minute with no water to cool the motor or exhaust. Needless to say I was not happy. Called them out to the lake. They hooked it up, said it did not appear to cause any damage and I went on the lake. Rode about 1 hour. Oh by the way there is about 15 hours on the motor.
Oil still appears clear. The amount of smoke was light. Like I said I ran about one minute. The exhaust was hot but did not appear to damage the fiberglass or rubber.
Please any advise? Questions I need to ask. Should I change the oil? (Was running on the new oil). Inspect the exhaust from the inside? Compression check?
Lesson number 2, check it yourself, don't rely on the other man.
04-06-2014, 04:43 PM #2
Running the boat, for a short time will not hurt it. The impeller will take the most damage when no water is flowing in the cooling system.
You might insist on a new impeller. If you don't have water leaking ourt of the engine and the oil looks normal then don't worry about the minute or two you ran with no water.Malo <--- Means--Evil or Mean One. This explains a lot.
[COLOR="#696969"]
04-06-2014, 05:00 PM #3Junior Member
- Jan 2012
- 5
04-06-2014, 05:41 PM #4Senior Member
- May 2013
- 253
This would not be a insist on a new impeller, it would be a demand in my book. Keep the old one as a spare if it isn't cooked.
04-06-2014, 05:44 PM #5Senior Member
- May 2013
- 253
The smoke by the way was probably from the fogging oil in the cylinders burning off from the winterization process. Running it for a minute wouldn't have gotten it hot enough to cause smoke related issues.
04-06-2014, 05:45 PM #6
Like Mike said....I would insist on a new impeller as it was run dry...... I would check the hose from the exhaust to the muffler....this is where heat can damage/deteriorate the hose quickly.....if it is good and stiff and no signs of leaking or heat softening you are most likely fine with no damage occurring..... a minute is not a long period of time to run the motor without coolant....did your screen flash at you??
99 Outback LS. Sold
04-06-2014, 05:59 PM #7
I'd also have the oil changed as it breaks down when it gets hot.
SOLD
04-06-2014, 08:20 PM #8Junior Member
- Jan 2012
- 5
04-06-2014, 08:23 PM #9Junior Member
- Jan 2012
- 5
04-06-2014, 08:41 PM #10
