Thread: Heater install ?
05-13-2014, 03:39 PM #1Junior Member
- Sep 2013
- 22
Heater install ?
First off, I am newbie to a lot of this. My boat came with a heater brand new in the box, so I thought I would install it. I looked through most of the threads and have a handle on most of the install. My question is in the electrical. I think I have the switch figured out. However, what do most of you do for the main power line and ground. Do you run a direct hot line with fuse to battery, or is there a better way. I didn't see much in the other threads on the wiring.
Thanks a bunch
Jeff2007 Moomba Mobius LSV
05-13-2014, 05:09 PM #2Senior Member
- Aug 2011
- 2,522
Re: Heater install ?
Are you planning to use the switch that comes with the kit?
What switches do you have on the dash, I usually re-porpuse one of those so it matches, stereo or acc?
Sent from my Nexus 5 using Tapatalkhttp://www.instgram.com/jlyons30
2006 Moomba Mobius LSV - Sold
05-13-2014, 05:29 PM #3Junior Member
- Sep 2013
- 22
05-13-2014, 05:35 PM #4Senior Member
- Aug 2011
- 2,522
Tap a new +positive lead from the main battery wire or bus bar under the dash, with a 25 amp fuse.
05-13-2014, 05:40 PM #5Junior Member
- Sep 2013
- 22
05-13-2014, 06:12 PM #6Senior Member
- Aug 2011
- 2,522
05-13-2014, 06:14 PM #7Senior Member
- Aug 2011
- 2,522
See page 5, 3 speed heater diagram...
http://heatercraft.com/content/Insta...tal_Marine.pdfhttp://www.instgram.com/jlyons30
