Results 1 to 10 of 16
    Crosby TX
    Default 2010 outback v swim platform questions
    Today while on the lake my swim platform came off and sank to the bottom of the lake I guess. Noticed when we where surfing one side was lose so was trying to limp back to dock when the other side broke. First question is where can I get another one and second do they make a surf platform?
    On a NorCal Lake Somewhere!
    Quote Originally Posted by Cactus371 View Post
    Today while on the lake my swim platform came off and sank to the bottom of the lake I guess...
    Sorry, I cant help you on a replacement other than calling your local dealer (I am sure you already thought of that), but that really sucks! a four year old boat and the platform falls off? WTF!
    Eric.
    Crosby TX
    Yea I think a platform pin came out and then the water ripped it off
    Jul 2011
    Murrieta, CA
    I have been working on a surf platform this weekend. I have some hydroturf on the way for a top pad.
    Probably not a good alternative for your situation as your brackets are probably at the bottom of the lake.
    Used plywood encapsulated in fiberglass.
    2010 Moomba XLV
    340hp cat
    Gravity 3, wake plate
    Rad-a-cage
    1100 v-drive lockers
    1180 under the playpen
    Default Re: 2010 outback v swim platform questions
    That or use Tek..
    2006 Moomba Mobius LSV
    Apr 2012
    Did you check to make sure this isn't any damage to the transom?
    Crosby TX
    Yea I did the transom is good. The pin on one side came out then the platform broke away from the other side bracket. On the bright side looks like I'll be getting a surf platform now. Lol
    Jul 2013
    Cedar Falls, IA
    Replace those spring pins with some SS nuts & bolts!
    2013 Moomba Mojo 2.5
    2012 Ford F150 Ecoboost
    Aug 2008
    Hilliard, Ohio
    Or SS Pins from McMaster Carr
    May 2013
    That surf platform looks a lot like the one that we made (as a prototype) for my boat. made a huge difference.
    That said, YES, skier's choice does make a surf platform that you can buy OEM. IIRC, you'd be into it about $1000.
    http://www.supraboats.com/bbs/showth...-Swim-Platform
