Results 11 to 14 of 14
    Aug 2010
    OC Oregon
    My plan is to epoxy in a fitting with a petcock valve. The Teflon tape works just fine. No leaks. If there is any leaking it would be so small it really wouldn't hurt anything.
    2010 LSV
    Mar 2003
    Springfield Missouri
    Interesting - when did draining the mufflers become part of the winterization process? You would think the drain plug set up would be more robust. I don't even think my 98 has a drain plug and if it does it is lying on the floor where I couldn't get to it.
    SOLD
    Sep 2011
    Onsted, MI
    Here is the fix for the problem. Get your self a 5/16-18 self tapping bolt from Fastenal (item #32416)(5/16-18x3/4"HWSLTCS). Get a "performance tool" 125 piece rubber grommet set off ebay (item #5214). Remove the old stripped out bolt that you use to drain the water out of the muffler. Using a flat blade screw driver, reem out the hole until you are able to thread in the new self tapper. Put a rubber grommet on the self tapper. Tighten down (but not too tight). No more leaks!!!
    May 2015
    Woodlands/Conroe, TX area
    Default muffler drain plug
    Why not use a metal roofing screw? Already has the sealing washer.
    2008 Moomba Outback DD resurrection
