Page 2 of 5 FirstFirst 1234 ... LastLast
Results 11 to 20 of 47
Thread: Equalizer
  1. #11
    Oct 2010
    Lake Wylie NC Area
    The wet Sounds is absolutely a marine built piece of equipment. EQ's and head-units tend to be more out in the open, so going with a marine unit with a conformal coated PCB has its advantages, but it goes far beyond that.
    The WS-420SQ has chassis mounted RCA jacks on the back. the others have the RCA's soldered to the PCB and passing through the rear of the chassis.
    The WS-420 has dual zone equalization, the others have single. So the 420 allows you to fine tune the in-boat and tower zones independently of each other. On the others, what ever adjustments you make to the front zone, effects the rear zone, or in-boat and tower zones if the fronts been relabeled.
    The 420 has 3 independent volume zones. This is different from front/rear fade.
    The 420 has 6 discrete outputs as opposed to dividing the front/rear level through the fade.
    The 420's level adjustment are under the cover, so no holes in the top of the chassis where water can enter.
    The 420 has true sub volume control and no adjustable low-pass filter, which is not needed with modern amps.
  2. #12
    Jul 2011
    Murrieta, CA
    Default Equalizer
    I went with the Clarion for $56 since Exile is sold out of the zld. Works great so far.
    Interested to see what Exile has on the horizon. Will most likely upgrade the eq and the cabin speakers.
    2010 Moomba XLV
    340hp cat
    Gravity 3, wake plate
    Rad-a-cage
    1100 v-drive lockers
    1180 under the playpen
  3. #13
    Feb 2010
    Canton, Ga / Lake Lanier
    Default Equalizer
    Yep! What he said
    Skate: LF Faction 44
    Surf: LF Custom Quad & XXX
    Tow Rig:
  4. #14
    Mar 2014
    Park City, Utah
    Post a picture of how you have it all tied together, would love to see how you set your system up.
    2013 Supra SA450 with da FLOW
    2006 Mobius LSV - Sold
    2004 Stingray 190LS - Sold
    www.tffor.org
  5. #15
    Nov 2013
    Kansas City, MO
    I'm liking this Clarion idea. Can you post a write up on here Boone?
    2007 LSV
  6. #16
    Jul 2011
    Murrieta, CA
    Default Equalizer
    Quote Originally Posted by Beejwest View Post
    I am not an audiophile but the Clarion has been a nice budget solution for me. I still hope to run the Exile ZLD in the future but the Clarion is working for the time being.
    The Clarion will not allow true and full adjustment of the tower and cabin speakers as it will fade front/rear (tower/cabin). I have worked around this by leaving the front/rear fade at 12 o'clock giving full power to cabin and tower. I then run a PAC LC1 controller immediately attached to the EQ and before the tower amp so I can turn down the tower when I want to.
    So I can adjust the whole system volume, sub volume, and tower volume (I can only reduce tower volume when compared to system volume).
    When I buy the ZLD I will be able to just remove the clarion unit and PAC LC1 and plug the ZLD in. No rewiring requires.
    2010 Moomba XLV
    340hp cat
    Rad-a-cage
  7. #17
    May 2013
    Vancouver WA
    Exactly. The ws unit really offers more control than the exile. I was on a boat with the new exile and saw the cabin speakers being over driven by the bass of a particular song. I told the driver to turn down the bass on the cabin speakers. He was able to turn down the bass, but on the system as a whole. Lame. Obviously the sub and the xl9 towers could take more than a 6.5" speaker. But no independent eq by zone on the exile. The knob layout on the ws is better in my opinion. The pop out buttons on the exile were too close together since you could only turn them with the side of the buttons, where as my ws420 sq can adjust the buttons more from the top of the button.
    There are wasteful buttons on the exile... Seriously, who needs to have a knob to change the phase of the sub on the eq???? Likewise, do I need to change the crossover frequency of my sub on the fly? Um, no.
    The ws can do both red or blue illumination. I kinda like the built in P. A. System. I have used it to coach surfers.
    Also, the ws has an aux output so I can feed my music to another boat... Like if we were rafted up and I wanted my music playing off both boats systems. (or many if you Daisy chained the ws420 's.)
    The exile is a cool unit, but for the same $300 retail price, why wouldn't you want the one with eq controls for BOTH the cabin and tower zones, plus the other features it has?
    Sorry, but the 420sq is the clear winner to me.
  8. #18
    Nov 2013
    Kansas City, MO
    I have the opposite problem I guess. My wife gets blown out by the cabin speakers, and I want the tower louder when I surf. Would the Clarion work to fade out some cabin volume and allow higher tower volume without the LC1?
    2007 LSV
  9. #19
    Jul 2011
    Murrieta, CA
    Default Equalizer
    You could certainly fade to more tower and less cabin with the front/rear fade built into the Clarion EQ.
    Connect tower to front or rear EQ output and the cabins to the outputs not used by the tower.
    2010 Moomba XLV
    340hp cat
    Rad-a-cage
  10. #20
    Oct 2010
    Lake Wylie NC Area
    or use a simple line level control in line on the RCA going to the cabin amp. Tower amp runs at head-unit volume, while the Line line level brings down the in-boat amp volume.
    A better solution would be a zone volume controller like the Kicker ZXM-RLC. its a 9V per zone line driver and does not require long RCA runs like an EQ, when the amps are on the port side. The control knobs can be panel or surface mounted.
