Results 11 to 20 of 29
  1. #11
    we actually got out on saturday and started messing around, the best wake for my boat, 750 rear locker filled, center bag full, 400lb on the surf side (middle) on the seat, and in the bow, surf side (on the seat). next time out, I am going to try putting some more weight in the (non surf side). The wake was pretty clean on either side doing this. we were trying out a new board, so we will need some more time on the water to keep playing with the wake.
    B.J. Reed
    2006 Moomba OBV
  2. #12
    Aug 2011
    Default Re: Size Sacs for 06 OBV
    Add an IBS or a 750 up front..
    2002 Moomba Mobius LSV - Sold
    2006 Moomba Mobius LSV - Sold
  3. #13
    just a sac or the v (bow sac)?
    B.J. Reed
    2006 Moomba OBV
  4. #14
    Aug 2011
    We share the same hull..02 LSV and 06+ OBV
    I run:
    650 IBS
    400 Center
    400 Under Port Seat
    750 Port Rear
    300-750 near the port seat..
    The biggest difference for me is water depth, the deeper the better...
  5. #15
    Feb 2014
    High Ridge MO
    Quote Originally Posted by beej77r View Post
    ordered my 750's from wakemakers along with bag vents. Will be able to test on Saturday. Going to put one of my previous 400's up front in the bow, and possible the other on the floor. will see how it goes one thing at time...
    I've been thinking about doing the same thing. How does the boat handle the weight
    2008 Outback V
    Gravity III ballast
    750 rear lockers
    Stock center
  6. #16
    Aug 2011
    Handles? The boat goes where ever it wants, you just hope it's near where you want to go.
  7. #17
    [QUOTE=Klos;241137]I've been thinking about doing the same thing. How does the boat handle the weight[/QUOTE
    Its like a big heavy TUG BOAT! I had a hard time getting it on plane when we were going to another spot. it took alot of throttle to get it up to go... other wise it handles fine, you just need to be aware of how much weight you got in the boat. if you are just surfing and doing the 11 mph, you are fine. but with that much weight added, I wouldn't go across the lake like that if you weren't actually surfing. Def going to consider a different prop!
    B.J. Reed
    2006 Moomba OBV
  8. #18
    I ran 750 rear, 400 center and 650 ibs with the standard prop in the OBV 07 and it handles sluggishly, plus be prepared for rollers with that nose weight in that boat.
    Feb 2014
    High Ridge MO
    That's what I kind of figure. I guess a prop will be there next purchase after I upgrade the ballast.
    2008 Outback V
    Gravity III ballast
    750 rear lockers
    Stock center
  10. #20
    jmvotto- how was your surf wake running this configuration? i am curious with the 650 up front? been considering it...
    B.J. Reed
    2006 Moomba OBV
