Thread: Stock Amp Rack
    Jul 2010
    Vicksburg, MI
    Default Stock Amp Rack
    I ordered my new LSV with just the standard stereo and 4 in boat speakers, and I was told that the boat would not come with the amp rack. I ordered the onboard charger, which is usually mounted to the amp rack. Does anyone know if the amp rack will now be included?
    Joe
    2014 LSV
    2010 Outback V - Sold
    1993 Echelon
    Oct 2010
    Lake Wylie NC Area
    Not getting the stock amp rack could be a good thing. One particular tow boat manufacturer pre-cuts 3 large squares out where the amps will go, before wrapping the carpet over the board. The was is useless if your plan is to do anything other than the 3 OEM amps in the OEM arrangement. One other only cuts the rack to fit the 2 OEM options. SO again, its no use if you are doing more than 2 or larger amps then the factory offerings. Building your own allows you to lay out the components like you want.
    Ive collected 3 of them, in which we cut up and use the HDPE for fabrication on other projects.
    Quote Originally Posted by jstenger View Post
    I can't speak for sure, but the Mojo when we got it was ordered as a Stock stereo with Bow Speaker option and charger. It had an amp rack, they mounted the charger, amp, circuit breaker and ground block to it.
    I had to take it out because it was too small.
    Slightly different now.
    If for some reason you dont get a rack, and want one I kept my factory one and we can talk about measurements and see if it will fit.
    Nov 2003
    Land O Lakes, Florida
    think my amp board looked like Mikes in the above photo, I ordered the bow speakers
    Hey, Its Moomba time
    13 Mobius LSV-sold
    08 Mobius LSV-sold
    03 Mobius LSV-sold
