Results 1 to 6 of 6
    NOVA
    Question Direct drive prop experiences? looking for advice
    Hello all... long time lurker first time poster.
    I've searched many many sites and spoken to a few people about prop selection but can't find any info relating to my specific DD and 3 blade props.
    I've been told and have read that 3 blades are better on the 1:1 ratio for DD's - I'm okay with this.
    I'm hoping someone might have experience with either the Acme 543 or the 1229...
    The boat is an 07 mob LS 21' DD - we usually ride with 6-8 adults on board, Gravity III system filled, + #1000 between two other bags, an extra #700 for surfing.
    With that setup the stock prop is obviously not cutting it, but it's hasn't ever failed to get a rider up.
    I'd hate to go too extreme re-propping which makes me afraid of the 1229, I don't mind scrubbing 4-5 mph off the top but sometimes getting to the glass quickly is nice.
    tl,dr: Do I go with a 543 or a 1229
    Call Nettles and tell them all your info. They are the pros and can make the recommendation. If you don't like it I'm sure you can swap it with them.
    http://www.nettleprops.com/
    Irondequoit Bay, NY
    plus 1..thats what i did..i called nettles and they told me what prop and thats what i bought
    Rockford fasgate cabins
    Exile XM7's
    Exile Harpoon
    Exile ZLD
    Polk 10in sub (2)
    Polk P330 amp (subs)
    May 2013
    Vancouver WA
    Well, I can tell you that I have a 92 Supra Sunsport DD with the PCM 351 Pro Boss (285hp). The previous owner put an 13x11.25 prop on mine (which is the same spec as the Acme 543). He was into wakeboarding and only sometimes surfed.
    I am more like 60 to 70% surf and 40% wakeboard. I will slalom every now and then just to prove I still can.
    I think the prop is fine for my needs. I will load the boat down with 1300 to 1500 pounds regularly. Yeah, when I'm maxxing out the ballast I'm pretty much maxxing out my engine's ability at surf speeds. But it's worked fine so far.
    I did a top speed run once and my boat went 43mph at 5600 RPM's (which I know is too high on the RPM's, but I had to try it. That said, I can get the boat in the 30's fine without over-revving it.
    ***Keep in mind that I have the 1:1 transmission. Everything would change with a gear reduction tranny like the 1.23:1 But you seemed to imply that you had a 1:1 like me. But I know Supra used different trannies so check first as Moomba might have also!!!
    You COULD go to a 13x10.5 if you really want to focus on surfing. It's a tough call.
    Jun 2006
    Quote Originally Posted by chushen View Post
    I have a 2004 LS. I switch from the stock OJ prop to an ACME 543 years ago and have never looked back. It felt like a performance upgrade and easier on your motor when running increased ballast.
    2004 LS with 1000 Salt Water Hours.....
    Irondequoit Bay, NY
    i have the 543 as well
    Exile XM7's
    Exile Harpoon
    Exile ZLD
    Polk 10in sub (2)
