Thread: Eight.3
    Irondequoit Bay, NY
    Default Eight.3
    sooo am i seeing this right? it looks like ronix has two versions of the bag. a plug and play and then the telescoping bag style?. i also see two priced for the 800lbs bags. bakesonline.com has the 800lbs bag for $127, and wakemakers.com has the 800lbs telescoping bag for 229$. Maybe im reading something wrong or not reading at all haha. if they are both the same then i might as well go over to bakes and grab them for 100$ cheaper..
    http://bakesonline.com/detail.aspx?ID=3186
    http://www.wakemakers.com/ronix-eigh...e-ctn-800.html
    Rockford fasgate cabins
    Exile XM7's
    Exile Harpoon
    Exile ZLD
    Polk 10in sub (2)
    Polk P330 amp (subs)
    Arkansas
    I feel like the wakemakers one comes with the pump but it's hard to tell.
    Good question, I just sent someone to wakemakers the other day. Surely they aren't that much higher.
    2016 Moomba Mojo
    2006 Supra 24SSV - Traded
    Arkansas
    If you compare the telescoping bag to the telescoping bag the prices are closer ....
    http://bakesonline.com/detail.aspx?ID=3190
    and by closer, I guess I mean the same.
    2016 Moomba Mojo
    Yea, those are two different bags.
    Irondequoit Bay, NY
    ok. so i guess you can plumb in the eight.3's into your system then if you buy the plug and plays. im looking at the telescoping ones for the outback
    Exile XM7's
    Exile Harpoon
    Exile ZLD
    Polk 10in sub (2)
