Results 1 to 10 of 13
Thread: Stereo upgrade
    Aug 2010
    Nokomis, Saskatchewan
    Default Stereo upgrade
    Ok... so my new mondo comes with the kicker amp but no tower speakers... which is what I wanted anyways... need me some exile!! What are your thots on the following
    1. Use kicker amp to power a sub
    2. Buy 2 tower speakers SXT9Q'S
    3. Buy amp to power the 4 in cabin speakers and the 2 towers. 800.4?
    Can I run the towers off of 2 channels of the 800.4 and run the in cabins in series which would provide way more juice than the deck is giving them now..??
    Cheers
    Geoff
    Sent from my apple crushin android device
    2014 Mondo with da flow!!! Exile towers, stock everything else.... for now!
    Aug 2010
    Or I could get the Javelin I stead of the 800.4 which wpuld run the in cabins and sub then go with a harpoon + 2 sxt9q's package.... then I could get 2 more towers down the road
    Oct 2010
    Lake Wylie NC Area
    Rather then 20th century class-A/B amps, I would consider the more efficient Class-D
    Will you be keeping the stock sub? Once the speakers are chosen, the amp options fall in line. A nice efficient Class-D 4 chnl can power 2 pair of in-boats and a moderate 10" sub, but no room to add a 3rd pair of in-boats. For 3 pair and a sub, a 5 or 6 chnl is a great option. Quite a few proven efficient Class-D 5 and 6 chnl amps out there.
    For tower speakers, I would suggest a dedicated amp. Being high on a tower as wells what we expect out of them, they will need way more wattage then the in-boats. Sharing 1 half of a 4 chnl with the in-boats rarely offer this needed power. For tower speakers, a 2 chnl is a great way to go as it will allow for a 2nd pair later. But, a 4 chnl run in 2 chnl mode can be a budget friendly way to power a single pair of tower speakers.
    Aug 2010
    My boat didnt come with a sub.. so ill need get one
    Oct 2009
    Pacific NW USA
    Sask -
    Nothing wrong with the way your talking about doing it, but let me give you a few things to think about down the road.
    The 800.4 that your speaking about is discontinued and I'm fairly certain we sold off the last of that model. It's been replaced by the XM15.4 model. If you do go with the SXT9 pair, you could run it in stereo mode and deliver 150x4 CEA rated power. You'd run ch 1-2 on the tower and then you'd have ch 3-4 to power either cabins or a sub. If you summed 3+4 to the sub, you'd have 300 watts.
    The other option is to run the Javelin in the cabin / sub. This would give you 120x4 CEA for the cabin and 800W for the sub. As a side note: you could opt to keep the factory cabin amp in play and dedicate the javelin to the TOWER and SUB by bridging ch 1+2 and 3+4.
    The point of this is to let you know - You have options. The Javelin will be most flexible but cost more. Hit me up in a PM if you need in-depth info. Happy to help.
    -Brian
    saskyrider,
    Before you make an amplifier selection, how many sets of pre-amps do you have on your HU, and do you plan on getting an EQ right away?
    Aug 2010
    I plan on getting a ZLD right away im not sure on pre amps on HU I dont take delivery of boat until april.
    Quote Originally Posted by saskyrider View Post
    Good. If you are using an EQ then you are in good shape. There are definite conflicts with the above system if you only had a source unit with dual pre outs.
    Aug 2010
    Ya I had the ZLD in my last boat and really liked it... I actually did away with the HU all together. Bluetooth my phone to the ZLD using a bluetooth puck plugged into a set of pre outs on the back of the ZLD.. very convenient
    Tooele UT....
    someone (david ) told me years ago when designing my first system that if you are not going to run 3 amps, to keep the towers independent of the sub from an amp standpoint. the theory was that you want to balance out the "power hungry" sides of the system to different amps. it made sense to me. I have always ran 3 amps so it was kind of a moot point other than it pushed me into that setup for the first boat and I followed to the second.
    my .02...
