Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
  1. #11
    May 2010
    North Dallas, TX
    I second what navajake said. I use 3M products, including rubbing compound. The variable speed polisher is key, especially for tough scratches. I was a little frustrated when I saw that a lot of scratches weren't coming out after the variable speed polishing. I started to try wetsanding starting with a 2000 grit sandpaper and going very slow. I followed that up with the rubbing compound, polish, wax and the Finesse-It II and I could not believe what a difference. The variable speed polisher is an investment, but they are not too expensive. I use mine all the time. It is amazing how many times the wakeboards hit the side of the boat, no matter how fast I jump from the drivers seat to help out. Good Luck!
  2. #12
    Aug 2013
    Virginia
  3. #13
    Jul 2013
    Saskatoon, Saskatchewan
    Very informative. Thanks for the information.
  4. #14
    Article makes (at least) two good points-- only do as much as you have to, i.e., don't sand if you only need to polish; and horizontal surfaces will usually take more effort than vertical. Good stuff.
    Mar 2012
    South Carolina
    Default removal of scuff marks in gel coat?
    I still have to get my lazy ass on this project.
