Results 1 to 10 of 15
    Mar 2012
    South Carolina
    Default removal of scuff marks in gel coat?
    I have a couple of scuff marks that I want to get out of my gel coat. They happened on a sketchy entrance to an even sketchier ramp during a swift high tide. I am wondering what I can do to get them out.
    It seems tapatalk now requires users to sign in with a tapatalk ID to post pictures, which I am too lazy to do right now because I am tired of every site requiring some sort of ID/password. Anywho, if you want a pic I will see if my phone can post it since I havent upgraded to the new tapatalk.
    Mar 2012
    South Carolina
    Aug 2011
    Default Re: removal of scuff marks in gel coat?
    Rubbing compound.. Start with the lest abrasive you can find and a buffer, then move to more abrasive if needed..
    2002 Moomba Mobius LSV - Sold
    2006 Moomba Mobius LSV
    Those may even come off with a marine wax that has an oxidation remover/cleaner that would be a little less abrasive than rubbing compound.
    Drew
    2016 Supra SA 450
    2015 Supra SG 450
    2012 Moomba Mojo
    2008 Moomba OBV
    Pensacola, FL
    I would start with a cleaner/wax. Then use a rubbing compound. It's hard to tell if there is gel coat damage. If there is, youtube gel coat repair and you can get a lot of good info there.
    1997 MasterCraft 205
    2008 Moomba Outback
    1999 MasterCraft Sportstar OB
    1992 MasterCraft 205
    1999 Malibu Response LX
    1987 Marlin Magnum Skier
    Mar 2012
    South Carolina
    I'll check into some waxes at west marine to see what I can find.
    I've used this a few times for light marks and then followed up with a good, reg wax.
    http://www.westmarine.com/webapp/wcs...classNum=50281
    Drew
    2016 Supra SA 450
    2015 Supra SG 450
    2012 Moomba Mojo
    2008 Moomba OBV
    Aug 2011
    I use this one...
    http://m.westmarine.com/aHR0cDovL3d3...3D#description
    Portland Oregon
    Green first blue second
    -Jake
    Jan 2014
    I just restored my gelcoat with a wetsand, compound, polish and wax process...i'd get a black foam finishing pad and use 3m finesse-it II. You'll be amazed at how well that works. Some guys say that an orbital doesn't do enough and to use a variable speed polisher. I happen to have both and tested it out, the variable speed is much quicker, but the electric d/a i got from harbor freight worked just as good and seemed to work better on my black gel coat areas. If you get up super close in the right light you'll still notice micro scratches but they are less noticeable with the d/a. Foam pads are color coded and black is the finest cut, white is in the middle, yellow would be heavier more for compounding. You can even use finesse-it by hand and it works great. Id say use a straight wax afterward for more protection, but i'm no expert as this was my first attempt.
