Results 11 to 15 of 15
    Dec 2013
    Next time out lift the engine hatch after you have run it for 30 mins, then after a 20 min wait , see if it starts and stays running, if it does then you have confirmed vapour lock. Then the best way to solve may be install a high volume, low pressure pump on your line as close to the fuel tank as possible
    Thanks for your reply, I think I have a vapour lock problem and I am considering installing the 2nd pump. Do you perhaps have the specs for a high volume low pressure pump. This will help me in buying the correct pump.
    Quote Originally Posted by Charl View Post
    Thank you for the reply
    I have a 13,7 x 17,5
    Any idea what prop I should use for my conditions (I am 4000 ft above sea level_
    Also what does the 13,7 and the 17.5 stand for?
    The ACME site explains how to read your propeller.
    http://www.acmemarine.com/our_props.php
    The numbers stand for diameter and pitch.
    I just called ACME and gave them all of your information. The salesman said you are running a "4th gear prop" and at your altitude you can't get the RPM you want out of it.
    He recommends going to the ACME 537 which is a 13.5 x 16 prop. Or, for even more low end pull for wakeboarding but giving up some top speed, you can go to the ACME 1579, which is a 13.5 x 14.25 prop.
    I hope this helps you.
    Dec 2013
    Thanks this helps a lot. I have decided to go with the 1579.
    Before I can place an order I need to be sure of the shaft size and rotation of my boat.
    ACME has suggested that I contact MB and post my Hull ID ( US-ISRML006H405 )
    Is there anyway that you can check for me ?
    Also ACME does not want to sell directly to me in South Africa and we do not have any dealers here.
    Any suggestions???
    Oct 2013
    Ft. Collins, CO
    Here, let me google that for you:
    https://www.google.com/shopping/prod...67982277063634
    Wakemakers has a good price new or used and ship internationally.
    1989 Sanger Skier DX - sold
