    Jan 2014
    Default Part needed for my 2000 Moomba Mobius but do not know what it is called???
    I need to find a replacement part for our 2000 Moomba Mobuis but not sure what the part name is. It's located on the back lower portion of the boat & there is one of each side. Please see the attached picture. We believe it is part of the ballast system where the water is sucked it but not sure. Thanks for any help you can give!
    May 2011
    Fort Worth
    I think that is the speedo??? Others may know better
    '08 Mobius LS
    I would concur -- looks like the speedo to me
    Mike
    Nov 2009
    Did it break off? If it isn't leaking time to install PP stargazer with GPS for speed.
    -Mark
    "Hey you only live once"
    Jan 2014
    Thanks guys! That's what it is & going to get two new ones ordered!
    Default Re: Part needed for my 2000 Moomba Mobius but do not know what it is called???
    Why bother, use that money for a prefect pass..
    2006 Moomba Mobius LSV
    Tuscaloosa, Alabama
    It is called a pitot(sp) tube.
    Jack Beams
    '05 Outback DD
    325HP EFI Indmar
    Oct 2013
    Ft. Collins, CO
    Why are you replacing them? Pitot tubes commonly get plugged with sediment and the result is the speedo fails. You can usually unscrew the tube and clean things out.
    But if you didn't know it was part of the speedo... how did you know it needed to be replaced?
    1989 Sanger Skier DX - sold
    Aug 2013
    DFW
    ^^^^^ this
    Matt
    2016 Mojo
    2012 LSV (sold)
    Need to pull the line loose from the back of the speedometer and blow it out. They get water up in them sometimes. Or they get pinched. That's why you have two speedos for tournament use. If they were worth a crap you'd only need one. (By the way, you can make your boat a lot faster by drilling the hole out a little bit.)
