Page 19 of 33 FirstFirst ... 9171819202129 ... LastLast
Results 181 to 190 of 329
  1. #181
    Oct 2008
    Central, Arkansas
    I hope so because with my ballast I could surf in the next zipcode.
    now that is funny..
  2. #182
    Aug 2011
    You still need to run ballast, just now you run it equal on both sides.
    It is a manual tab you pull down on the opposite side you surf. Reg surf you deploy the Star tab. Goofy surf you deploy the Reg side.
    This does allow faster switching between sides.
    It also causes the wave to form farther behind the boat, in effect making you surf farther behind the boat.
    I have not riden any of the systems, Swell, Surf Gate, NSS.
    I've ridden on the G23 which has totally ruined my experience with my LSV... If only I had $150K....
    2002 Moomba Mobius LSV - Sold
    2006 Moomba Mobius LSV
  3. #183
    Got the official word today.
    Boat goes in on March 17th for several upgrades.
    The 3 I can mention are.
    1. Moomba Flow System
    2. Black out Moomba letters, No more plasti-dip on my side letters.
    3. 2014 Swim Deck Brackets.
    After some other work is done I should have her back by end of March and if weather gives me 55 and no rain I will finally get my first surf of 14 in.
  4. #184
    Aug 2013
    DFW
    Default Moomba Flow The new Wake Enhancement Device
    What are the ones you can't mention???
    Matt
    2016 Mojo
    2012 LSV (sold)
  5. #185
    Jul 2011
    Murrieta, CA
    Stripper pole
    2010 Moomba XLV
    340hp cat
    Gravity 3, wake plate
    Rad-a-cage
    1100 v-drive lockers
    1180 under the playpen
  6. #186
    Jul 2013
    Cedar Falls, IA
    I'm very curious about #3 here... Last year I was told the 14 brackets were not retro'able. Moomba paid warranty to replace my brackets when my swim platform was wobbling an inch after a few months... But they are still the 13 style so I doubt they will last.
    2013 Moomba Mojo 2.5
    Exile SXT9's, Xi12D, Javelin, 800.4, ZLD MKII
    SUMO 900's in rear, 650 IBS and FLOW
    2012 Ford F150 Ecoboost
  7. #187
    Quote Originally Posted by uniwarking View Post
    My experience has been less then pleasing with Moomba Swim brackets.
    08 LSV would rattle so bad I could hear it while surfing over my stereo. Drove me nuts.
    13 Mojo second time out the little factory screws stripped out, dealer had to remove them. They installed some larger 2.5 inch long bolts. Each time we went out I had to tighten it a little more, and a little more. In July due to the bolts putting so much pressure on the brackets, the bottom pin that holds the swim deck in the bracket sheered off and I almost had the swim deck come out of the bracket.
    Got new bolts, by the end of the summer, and the current way they are now is 4 bent bolts, that wont come out of the brackets, and the rails on the swim deck are bent, missing metal.
    Option 1 is let the factory do a warrenty repair and I get the exact same set up just to go through all this again in 14.
    Option 2 work out an agreement on 14 brackets and pay the bill.
    Your right on the 14 brackets don't just bolt up. They have to drill some new holes and such. This is part of the reason my boat will be in the shop so long. They will have to do a little gel work on the rear to make everything look right. I will def get you guys pictures of the work after.
    This could very well be your next year upgrade. Some upgrades seem like they should be factory but they aren't.
    As for the letters, I have 2 people already interested in them.
    AWS said they will try to remove them gingerly but ultimatly they dont expect them to be reusable. IDK we will see.
    I am mainly upgrading to the black because I'm a stickler for how my boat looks, and just 1 bump on the dock pad makes the plasti-dip peel and I don't like respraying them every few weeks to make them look black. I have to fork out the money for the new upgraded Black letters but in the end I think its money well spent.
  8. #188
    Jul 2013
    Saskatoon, Saskatchewan
    I am interested in the black chrome letters. What is the cost from your dealer or did you order them locally?
  9. #189
    The best part about the surf systems in my opinion is you can instantly go from wakeboarding to surfing without having to drain one side and out a bag on this seat ect ect. The ability to just use one ballast set up and go from side to side and boarding to surfing is a huge advantage. I might actually surf if I had a system like this
    Sent from my iPhone
  10. #190
    Jul 2013
    Cedar Falls, IA
    Sent from my iPhone
    Agreed. The system seems easy and appears to produce a nice clean wave. It also reduces the need for additional investment and lost storage due to ballast improvements.
    I want the Flow... Just hard to stomach the bill... Especially with all I've spent an am continuing to spend on Exile gear!
    My dealer seems to be a way off from where other dealers are as far as purchase and install cost goes... that's my major hang up right now.
