Page 18 of 33 FirstFirst ... 8161718192028 ... LastLast
Results 171 to 180 of 329
  1. #171
    Sep 2013
    cape cod
    Did you order your flow unit from wake makers or Moomba directly?
  2. #172
    Default Moomba Flow The new Wake Enhancement Device
    Moomba FLOW is only available thru dealers as far as I know.
  3. #173
    Quote Originally Posted by Mfeeney View Post
    My dealer.
    When AWS placed the dealer order for there current stock of boats, they ordered 1 extra knowing my boat would get one installed.
  4. #174
    Sep 2013
    cape cod
    Thank you for the reply
  5. #175
    Aug 2011
    Default Re: Moomba Flow The new Wake Enhancement Device
    I guess I'm still confused, does this improve the wave or just allow you to switch sides easier. Seems like you still need to run ballast, just that it's not all on one side...
    Has anyone ridden these surf gate waves?
    2002 Moomba Mobius LSV - Sold
    2006 Moomba Mobius LSV
  6. #176
    Quote Originally Posted by parrothd View Post
    You still need to run ballast, just now you run it equal on both sides.
    It is a manual tab you pull down on the opposite side you surf. Reg surf you deploy the Star tab. Goofy surf you deploy the Reg side.
    This does allow faster switching between sides.
    It also causes the wave to form farther behind the boat, in effect making you surf farther behind the boat.
    I have not riden any of the systems, Swell, Surf Gate, NSS.
  7. #177
    Jul 2011
    Murrieta, CA
    It really depend on what you want. Easy setup/quick switches form side to side or pro sized wakes.
    I think the new surf systems will
    give want most people will want/need but to get the pro wave you will need to slam the boat.
    IMO having the choice of a surf enhancer and the traditional ballast would be ideal. Easy setup when you want it and tsunami when you want that.
    2010 Moomba XLV
    340hp cat
    Gravity 3, wake plate
    Rad-a-cage
    1100 v-drive lockers
    1180 under the playpen
  8. #178
    Mar 2013
    My dealer took a mojo out and said with the stock ballast and flow you could easily surf 20 feet behind boat
    2013 Moomba LSV
    2013 LSV
    2006 outback DD sold
    2004 Stingray 180LX sold
    Quote Originally Posted by Sharpshooter View Post
    2013 Moomba LSV
    I hope so because with my ballast I could surf in the next zipcode.
  10. #180
    Oct 2013
    Can you get it on a 13 obv
    Sent from my iPhone using Tapatalkh
    2013 outbackv
