Results 1 to 10 of 10
    Oct 2013
    Ft. Collins, CO
    Default bilge pump not mounted to anything
    I'm just learning my way around the '07 LSV. While winterizing, I vacuum up every bit of water in the bilge. I noticed that my bilge pump isn't mounted to the hull in any way. On my previous boat there was a screw that went into a metal plate that there for some other purpose (skeg maybe?). It seems weird that the pump would just sit there not attached to anything. Is this normal or should it be attached somehow?
    I'm stealing a photo from cab13367 as it looks the same:
    http://i250.photobucket.com/albums/g...7/IMG_6349.jpg
    1989 Sanger Skier DX - sold
    Jul 2011
    Murrieta, CA
    My bilge pump is epoxied to the hull bottom.
    2010 Moomba XLV
    340hp cat
    Gravity 3, wake plate
    Rad-a-cage
    1100 v-drive lockers
    1180 under the playpen
    Oct 2013
    Ft. Collins, CO
    Quote Originally Posted by Boonejeepin View Post
    Does yours have some kind of mounting cup that is epoxied in and then the pump can be easily installed/removed/serviced? Mine just has the pump. If I glued it down, I would have no way to service it.
    Nov 2003
    Land O Lakes, Florida
    you should have base that is stuck to the hull and then the pump would clip to the base, unclip to clean or service
    Hey, Its Moomba time
    13 Mobius LSV-sold
    08 Mobius LSV-sold
    03 Mobius LSV-sold
    yes , what Daze said....
    Jul 2002
    London Ontario Canada
    My boat is glued to the bottom of the bilge pump housing. I can easily remove my boat for servicing if needed.
    09 21v LAUNCH
    99 Outback LS. Sold
    Doug
    Jul 2010
    Vicksburg, MI
    Quote Originally Posted by DOCDRS View Post
    WOW!!! You must have a pretty big bilge, if your boat is glued to the bottom of it. LOL!
    Joe
    2014 LSV
    2010 Outback V - Sold
    1993 Echelon
    On this topic, I had to remove a screen and clean it on the Bilge because my bilge would stay on all the time.
    I never had to do that on my LSV so im not sure what year or when they added a screen.
    Mine was odly enough, filled with fiberglass, dirt, and carpet fibers. I figured it would be hair from the Oso and Claudia, thats what i find in the bath tube drain all the time LOL
    Jul 2002
    My bilge pump hasn't come on in 3 years I should prob check to make sureit still runs
    09 21v LAUNCH
    99 Outback LS. Sold
    Doug
    May 2013
    Lake Anna, VA
    Shouldn't it be back near the transom? That is were the water goes when you are moving.
    2007 XLV Gravity Games
    1,100 in each rear locker
    1,180 in front
    Fresh Air Exhaust
    SuckG8
    Bunch of other crap
