Results 1 to 10 of 16
Thread: Removing gas
    Apr 2013
    Spokane WA
    Default Removing gas
    Any ideas on how to remove 40 gallons of gas from the tank on my 2012 Mojo? Can't seam to locate a good siphon anywhere. Not sure if there is a tank drain ?
    2012 Mojo
    Apr 2010
    saskatchewan, canada
    i would get a siphon hose, or a fluid extractor, I have used a a 12 volt pump with a small hose.
    2017 Helix
    Wakemakers 1050s
    Bow bag ( Surf edition)
    Autowake
    Round up a couple diehard buddies, case of beer, surfboards, dry suit....
    agreed.
    why do you want/need to remove all that gas?
    Oxford, MI
    Best option...the jiggler!
    https://forum.moomba.com/showthread....nsferring-fuel
    If you're doing it for winterization...don't. Fill up the tank and put marine Sta-bil in it that has ethanol treatment.
    That Jiggler is da bomb!
    I know people hate to have a question answered with a questions, but what is the need to remove the gas? If its for winter storage, then add some layup treatment (think ethanol), run the engine for a few minutes, then be at ease for the winter, it will be fine.
    Apr 2013
    Spokane WA
    I guess I'm over thinking it then. I've added the marine version of Stabil and ran it for 10/15 minutes. Just seemed like a better way to go would be to circulate the stabil gas through the motor and then get the old gas out of the tank and refill with fresh in May...
    2012 Mojo
    Oxford, MI
    Quote Originally Posted by german88 View Post
    That's absolutely plenty. It's not old gas in the tank, it's fresh gas now and sta-bil will keep it fresh. You want to have your tank at least 95% full for winterization to prevent moisture from building up in the tank. Ethanol absorbs moisture, but the sta-bil with ethanol treatment prevents that. Some people drain their tanks and have no issues, but the majority of people will tell you to have it full for storage with a gas treatment.
    Salt Lake City, Utah
    This
    Scott
    2021 Craz
    1997 Sea Ray 190
    The more stabil you use the longer it will stay fresh
    99 Outback LS. Sold
