Thread: boat hoist
    Oct 2013
    Default boat hoist
    Any suggestions for purchasing a boat hoist for a 2003 Mobius? Water is about 3-4' deep. Whats best vertical or cantilever? Is the tower going to fit under a canopy and is there anything else I should be considering when making this purchase?
    I have a 4k vertical great lakes lift and love it, have to get the canopy extensions for the tower to fit unfolded.
    Where are you located?
    Oct 2013
    Located in Oakland County, Michigan.
    Hoist salesman asked about the size of the boats draft. When I told him 22" he said that, that seems pretty unlikley, but that is what the Mobius' manual says... do I need to factor in the size of the boats draft? What else should I consider when purchasing a used hoist?
    You are correct, salesman not so much... Draft will help determine the height of the bunks over the cross beam. My obv had the same draft and I set them 12 inches about the cross beams. Never a problem .
    Over weight for removal., plus manual crank, battery or electric winch choices.
