Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
  1. #11
    Sep 2010
    Lake wallenpaupack PA
    I have seen that thing on the different trailer part websites as I need a cap for one of my trailers.
    • How does it work? I know you turn it! What is actually doing the lock out?
    If you liok at the a60 in the attached link you will see a cutout above the reservoir. This lockout basically will slide into that cut out and freeze the unit
    http://www.bakesonline.com/detail.aspx?ID=849
  2. #12
    Jun 2013
    Got mine from TrailerandTruckParts.com -- $10 + shipping..........best price I found
    Mike
    2013 Outback V
  3. #13
    Oct 2013
    Stephen, Mn
    Looks like a must! I bought my boat and brought it to a yard to store. So here I was trying to back it up and like, WTH? It's Minnesota, it was dark out, wet, and cold by the time I was attempting this. So I told the girlfriend to get in the truck and back up. Of course, there was nothing to stop the hitch. I found a 5/16 bolt with a nut and adjusted it to fit the gap, then just happened to find some wire and there ya have it. Good thing there are still some good old things laying around old farm yards.
  4. #14
    Jun 2013
    Quote Originally Posted by Jer119 View Post
    I had a similar problem...........the storage place I use is basically a huge farm and uses a Bobcat to move all the boats around and has no wiring harness let alone a 5 wire hookup to defeat the backup "feature".
    Once again another "feature" that turns into a huge PIA!!!
    Mike
    2013 Outback V
  5. #15
    May 2013
    Vancouver WA
    What trailers does this work with? I have a SMP trailer on my 92 Supra. It has the spot for the side lockout, so that's what I assumed I'd have to use. Correct?
  6. #16
    Sep 2010
    That looks like a ufp a60 setup. If you have a plastic cap to access the reservoir then it should work. Replace the the plastic cap with the ufp lockout
  7. #17
    May 2013
    Vancouver WA
    Quote Originally Posted by lsvboombox View Post
    Yes, I have a plastic cap for my reservoir in the same location as you guys have pictured previously. I'll take a closer look at it soon.
