Results 1 to 10 of 14
    Flowery Branch, GA
    Default Information / opinions needed concerning an Oil Extractor
    I am looking to buy a oil extractor to start changing the fluids in our 2013 Moomba LSV. All I can find are ones that extract the oil from the dip stick - Are their any that you can hook to the hose that comes from the engine?? How many of you change your own oil? do any take to the dealer to change?? I did take our boat to the dealer for the first service but I can buy all kinda new tools / gadgets if I do this myself - Lots of savings!! Thanks for the help and advise!
    KRiley
    2013 Moomba LSV
    Exile xm9s
    Exile Amps
    Exile sub
    Aug 2008
    Cottage Grove, MN
    I just put the extractor hose down the remote drain hose that you are referring to. Works like a charm.
    2006 Outback V - Gone
    2008 LSV - Gone
    2013 other brand
    Flowery Branch, GA
    Thanks mnpracing! - Meant to say Remote Drain hose - Long day at work...
    KRiley
    2013 Moomba LSV
    Exile xm9s
    Exile Amps
    Exile sub
    Tooele UT....
    pela6000 ftw. takes a while but does a great job..
    http://www.harborfreight.com/multi-u...ump-66418.html
    Connected to remote drain hose, and out the transom plug into pan. 3-4 minute job.
    Mar 2012
    South Carolina
    I was spoiled when I was in NJ, I got to use my dads mityvac fluid extractor and now I miss it!
    Does that HF extractor really work without a mess? And the lines are long enough? Might be a temp solution for me until I get a mityvac
    Yeah - not bad at all. I had a few drips on the road but that was after I was done and pulled the tube to empty it for storage. I use a little piece over oversized tube as a coupler between the oil pan drain line and tubing on the pump. I don't expect it to last forever, but for the 1-2x a year I use it it's good. Thin warmed up oil is still the key.
    Portland Oregon
    Bought a fluid pump and set up a hose like this.
    This is my Ilmor setup, on my boat I remove the piece of hose and screw the female air compressor fitting onto my oil change hose in the boat.
    They make buckets with pumps attached to the lids but I made this for the same money at harbor freight, you could easily make cables that are long enough to hook to your boat battery and not put a battery on the cart.
    Here is my transmission attachment. Horrible pic but you can barely see the female compressor fitting on the left just like the one above I use for oil.
    -Jake
    Salt Lake City, Utah
    Mityvac 7201 is supposed to be really good. A mechanic friend of mine recommended it. Amazon has it for $75 and free shipping. I just ordered one.
    http://www.amazon.com/Mityvac-7201-F.../dp/B0002SR7TC
    Scott
    Mar 2012
    South Carolina
    this is what i used, dad had one and it was awesome! eventually i'll pick one up. too many other expenses right now
