Thread: Coolant Volume
    Jul 2002
    London Ontario Canada
    Default Coolant Volume
    I did an experiment today while winterizing my vdrive. I recovered and measured the volume of coolant/water in the vdrive, intake hoses,block,heater,exhaust manifold and muffler. I recovered 20 litres or 5 gallons of water. The muffler holds a fair bit of water. So for all those who think sucking up 5 gal of plumbing antifreeze is good you are mistaken. You need 30% prop glycol for protection to -40. If you are using 100% prop glycol then you would want 4 gallons of it. If your using -50 plumbing antifreeze you would need 40 gallons of it.
    So unless you have 100% prop glycol you need to drain your system to get any freeze protection IMO
    09 21v LAUNCH
    99 Outback LS. Sold
    Doug
    Nov 2003
    Land O Lakes, Florida
    5 gallons in the system, never ever would have thought it was that much.
    Hey, Its Moomba time
    13 Mobius LSV-sold
    08 Mobius LSV-sold
    03 Mobius LSV-sold
    May 2013
    Were would one put 40 gallons?
    Jul 2002
    Quote Originally Posted by cornrickey View Post
    Sorry , you would need only 35 gallons of -50 plumbing antifreeze to bring the water in your system to a 30% solution to give you -40 burst protection. If you can get 95% industrial prop glycol 4 gallons circulated into your system will bring the water down to a -50 burst protection
    09 21v LAUNCH
    99 Outback LS. Sold
    Doug
