Page 5 of 6 FirstFirst ... 3456 LastLast
Results 41 to 50 of 52
Thread: TV help???
  1. #41
    I think I bought a new mount ... $25 bucks to the door.
    2016 Moomba Mojo
    2006 Supra 24SSV - Traded
  2. #42
    On a NorCal Lake Somewhere!
    For new wall mounts, check out Monoprice they are also the ONLY place to get HDMI or any other cable.
    Eric.
  3. #43
    Yes, precisely. That's where all my mounts and cables came from.
    2016 Moomba Mojo
  4. #44
    Mar 2012
    South Carolina
    Default TV help???
    Just look up on the innerweb the specs for the model # of your TV. Look for the VESA mounting specs, should be something like 400x200 or 400x400 mm and the screws are standard metric screws, they should be either M5, M6 or M8. The length should be from 16mm to 30mm depending on which TV you have. A trip or two to your local hardware store should do it, a lot less than whenever I install new sprinklers!
    Found out they are M6 screws, previous owners didn't leave all the hardware. Called up Sanus Systems which is the company who built the mount and they were of help. Like you said, I can just pick up at any hardware store so that is what I am going to do right after work.
    Should be mounted tonight!!!
  5. #45
    Good deal...........
    You can say that again. Wish I was back in college.
    In Limbo....
    did you hang a lot of tv's on the wall in college??
  8. #48
    I bet it took a lot more work back then, working on those old style large and heavy ones, anyone can work on a skinny lightweight one, takes a real man to hang a hog!
    (good to see another Moomba thread go South!)
    Eric.
  9. #49
    Mar 2012
    South Carolina
    Default TV help???
    Ah this is why I love this forum!!!
  10. #50
    LMAOF.. made my afternoon! besides these idiots in Washington....
