Page 1 of 6 123 ... LastLast
Results 1 to 10 of 52
Thread: TV help???
    Default TV help???
    In the new house finally got around to mounting the 46 inch LCD sharp tv to the wall in the basement.
    Worked fine on the credenza , when finally hung, turn on power and only blue screen, can't get to menu, change inputs, volume etc. only power on/off.
    It is 6 yrs old, did it just die? Ugh!!
    Mar 2003
    s.e. washington state
    One way is to do an internet search. I found if a problem is common, you will have more information to work with than you need. If there is no information then your situation is unique and your system is probably toast. But I think you are in luck as others appear to have gone through the same trouble. Try this one as there appears to be a reset. Just don't push the red button.
    http://www.ehow.com/how_5242884_trou...arp-aquos.html
    Z, not sure I see where the hard reset is. I can't get to any menu items. Just power on/off. Did not see little red button instructions to avoid.
    Tooele UT....
    and here I thought this was going to be another 3page thread on deciding to buy a 27" lcd tv
    looks like the perfect time to contact new guy and get advice on adding a 100" projection....
    Yeah I thought about that too when I posted, I chuckeled....
    kids would love it, but basement is already finished and I don't have the room for one, just pissed this thing worked fine until I hung it on the wall....
    Put it back on the credenza?
    ^ That's gotta do it. Only logical explanation here.
    2016 Moomba Mojo
    2006 Supra 24SSV - Traded
    It's probably aliens. I have a tin foil hat I wear to keep their signals from interfering with my thoughts.
    On a NorCal Lake Somewhere!
    I gotta agree, except change it to a 135" 2:35 wide drop down screen and don't forget to add (2) 12" or 15" subs, then ceiling hang a JVC projector! then put your chairs about 10 to 12 feet away.
    See, even home theaters can have a "Zipper Effect"!!
    • Did you get that 46" TV working?
    Eric.
    Nope, gonna throw a 37 inch up I had laying around temporarily and take bergs advice on back to the credenza, should fix the problem.....
