Results 1 to 10 of 17
    Sugar Land, TX
    Default ***On water - wake plate issue***
    Need a little troubleshooting help. Wake plate won't move. Makes noise when I try to move down, no noise when I try to move up.
    I just installed my FAE. During installation I removed the bolt joining the ram to the plate for wrench clearance, but I didn't unplug any electric cables or anything like that. And there is nothing restricting the plate from moving - there is plenty of clearance.
    Any thoughts?
    Current: 2010 LSV
    Previous: 2007 Outback
    In Limbo....
    reservoir empty?
    Sugar Land, TX
    If I were a reservoir, where would I be?
    Current: 2010 LSV
    Jul 2012
    Pearland Texas
    Check the cylinder. Mine split long ways and i have no clue how. My dealer replaced it under warranty.
    Chris H.
    2012 Mojo
    Wake Life
    Mar 2012
    Spring, Texas
    Open the engine compartment and look in the front right corner. Smoke colored plastic top
    Wetsounds Rev 10's
    XS-650's
    Syn 6
    Syn 4
    WS-420
    Jul 2011
    SE MI
    I had trouble with mine this summer... Topped it off with ATF fluid and works perfectly...
    2008 LSV 1100s 650IBS Reversible Pumps w\Timers
    In Limbo....
    Quote Originally Posted by kevkev View Post
    had to fill mine typically once a season. messy job.
    invest in a good funnel that fits it and fill slowly.
    Oct 2008
    Central, Arkansas
    Your sig says '10 LSV. If so it is electric ram not hydraulic. Maybe it was going out and you noticed while working on the FAE
    Sugar Land, TX
    Default UPDATED: ***On water - wake plate issue***
    Could not find a reservoir to fill. Weird thing is it began working once I had the boat listed, but as soon as I emptied the sacs it wouldn't work again. This leads me to believe it is a low fluid issue, but mcdye says I should have an electric ram so fluid wouldn't matter. Now I'm super confused on where to start.
    Current: 2010 LSV
    Does it have 1 cylinder connecting the plate the hull or two?
