Results 1 to 10 of 10
Thread: Heater Help
    Sep 2013
    Bennett, N.C.
    Default Heater Help
    Hey new to this forum have loved all the info so far! Now I need help had the boat out today turned on the heater it runs fine on low but after about a min. on high it trips the breaker under the heater switch tried doing a search but no luck.
    2004 Mobius LSV 340 HP
    Gravity III Ballast
    750s in Rear
    Stock 400 in Front
    Dec 2004
    Cinci-Dayton
    Is the boat new to you or has it worked in the past?
    Naked red and white 2005 Moomba LSV
    Sep 2013
    Bennett, N.C.
    I've had it a couple of months talked to the folks I got it from and they said it had always worked for them.
    Gravity III Ballast
    750s in Rear
    Stock 400 in Front
    May 2010
    Salt Lake City, Utah
    I wonder if you have a loose connection somewhere. I would start with the obvious stuff like checking all electrical connection and make sure you have the right fuse in.
    Scott
    2007 Mobius LSV with a lot of great upgrades and mods
    Sep 2013
    Bennett, N.C.
    Thanks...looks like everything is connected I made sure and tried it again still the same runs on high about a min the trips the breaker.
    Gravity III Ballast
    750s in Rear
    Stock 400 in Front
    Aug 2011
    Default Re: Heater Help
    Call heater craft... probably need a new motor..
    2002 Moomba Mobius LSV - Sold
    2006 Moomba Mobius LSV
    Sep 2013
    Bennett, N.C.
    OK Thanks I'll try them tomorrow guess they have a web site?
    Gravity III Ballast
    750s in Rear
    Stock 400 in Front
    Dec 2006
    Tigard, Oregon
    Al
    Sep 2013
    Bennett, N.C.
    Thanks Al.
    Gravity III Ballast
    750s in Rear
    Stock 400 in Front
    Sep 2013
    Bennett, N.C.
    Talked to James today at Heater Crafter it was a bad breaker below the switch.Thanks for all the help and steering me in the right direction.
    Gravity III Ballast
    750s in Rear
    Stock 400 in Front
