Page 1 of 3 123 LastLast
Results 1 to 10 of 23
    May 2010
    Salt Lake City, Utah
    Default My first mod...Cooler removal
    So I decided to jump in with a fairly easy mod and do the cooler removal. I had read a few times about cutting it out and ordering an AO cooler that is soft sided that will fit right in. I didn't have a dremel tool so I decided to try an angle grinder I had. Probably not the best tool but worked ok. Toughest part was getting the blade into the corners. I tried to keep a shop vac going while working but still gets pretty messy.
    Attachment 18457Attachment 18458Attachment 18459Attachment 18460Attachment 18461
    Scott
    2007 Mobius LSV with a lot of great upgrades and mods
    May 2010
    Overall it was pretty easy. It's nice to have a cooler that works well and fits nicely under the seat
    Attachment 18462Attachment 18463Attachment 18464
    here is a link to the cooler if anyone is interested. I used the code SWA for a 10% discount.
    http://www.aocoolers.com/index.cfm?category=15
    Scott
    Congrats! Now put a surf bag under there!!!!!!
    Nice work!
    So the cooler specs say 8.5" high - do you have that much space between the floor and your seat bases that it doesn't have to compress at all?
    Aug 2010
    Orlando, FL
    Why is this done?
    2005 Air Nautique SV211 Team Edition
    99 Moomba Boomerang- Sold
    Jun 2013
    Oxford, MI
    So you can fit ballast under the left seats
    Sent from my SPH-D710 using Tapatalk 4
    Jun 2013
    Oxford, MI
    Or in op's case, looks like just for a better cooler!
    Aug 2013
    DFW
    Not sure what year it started, but in my 2012 the cooler was just held in by 4 screws. I didn't have to cut anything. The AO is much better, and much easier to get bevs to/from the boat.
    Matt
    2016 Mojo
    2012 LSV (sold)
    Jun 2013
    Connecticut
    I was thinking about doing this to my boat (2002 Outback LSV) so I can add additional ballast under the cooler but I heard after removal you need to brace that section. Anyone with a similar boat have that issue?
    2002 Moomba Outback LSV
    May 2010
    Quote Originally Posted by cham View Post
    Why is this done?
    I did it because the original cooler is really crappy at keeping anything cold and it was cracked as well. The cooler fits in perfect without any scrunching.
    Scott
