Results 1 to 6 of 6
    Apr 2010
    saskatchewan, canada
    Talking need a little help
    Hey guys was looking at fabing up some wake gates, does anybody know if my 05 lsv hull is the same as 03 supra 22 ssv??
    2005 Mobius LSV
    Gravity IV (750s rear, 400 mid and 650 bow)
    wakeplate, perfect pass,
    Not sure what stereo I have, but I have 3 amps 2 subs 6 x 6.5 mids and tweets and 4 tower speakers ( 2 x 8 inch and 2 x 6.5 and tweets)
    Fuel Injected
    1433 acme prop
    Jun 2013
    Connecticut
    Not sure if your hull is the same but here is a link that has a number of DIY's on wake/surf gates. The Malibu guy's are all over this....
    http://www.themalibucrew.com/forums/...d/?hl=poormans
    Checkout the Moomba Modifications section if you want info on the surf/trim tab install I'm doing.
    2002 Moomba Outback LSV
    May 2013
    linkynoworky
    Jun 2013
    Connecticut
    Try this:
    You might need to sign up for that board to see all the pics...
    Jun 2013
    Oxford, MI
    What does "same" mean? If you mean did they come out of the same mold, then no. They are also not the same length nor the same shape.
    You might want to consider the shape of the side of your hull while comparing yours to the 03 SSV...I believe the SSV is pretty flat on the side near the transom (similar hull to my old Launch), however I think yours might have some sort of shape to it and may not be quite flat (only speaking from pics since I have never really seen one in person). Might be something to think of when comparing setups.
    May 2013
    he means the same mold as in identical.
