Page 3 of 3 FirstFirst 123
Results 21 to 30 of 30
  1. #21
    Dec 2006
    Tigard, Oregon
    For those with an LSV, see page 8 of the thread below for a simple solution to this issue. I put a lock washer in the gap at the top and it eliminates the rattle. This may or may not work for you depending on the size of the gap.
    https://forum.moomba.com/showthread....asher+platform
    Al
  2. #22
    Apr 2011
    NY
    After about a year the set screws on mine ('13) are wearing dangerously close to going through the bracket. Anyone else see this?
    '06 Outback - Gone but not forgotten
    '13 Mojo
  3. #23
    Dec 2012
    Ennis, TX
    Default Sloppy Swim Platform - '13 Mojo
    Work with your dealership. I had mine replaced with the 14 platform brackets for around 250 out of pocket. Normally would run over a grand. Dealership ate the labor and gel work and SC helped with the bracket exchange. The new brackets are stainless with no slop at all.
    Shane
    2016 Supra SE
    EXILED
    6 XM9 Tower
    6 SX65M Cabin
    1 XI 800.4
    1 XI 1500.1
    2 MX 30.2
    EXILE ZLD MKII
    EXILE Blue tooth EXBT4
    Blue LEDs
  4. #24
    Jul 2013
    Cedar Falls, IA
    I'm looking at doing the same thing, problem is my dealer doesn't do gel work so I'd have to take it somewhere for hat part of the work. I'm sure I'll be in a little more $ to get mine done.
    I did replace the hardware, helps some.
    2013 Moomba Mojo 2.5
    Exile SXT9's, Xi12D, Javelin, 800.4, ZLD MKII
    SUMO 900's in rear, 650 IBS and FLOW
    2012 Ford F150 Ecoboost
  5. #25
    I think I might have been one of the first to do this this year. I was able to get SC to work with me and my dealer as part of a warranty. My brackets where really worn down plus I had longer screws installed that where all bent.
    Very worth every dollar.
  6. #26
    Jul 2013
    Whiteshell, MB
    Can anyone post a picture(s) with the old and new versions side by side?
    2012 Mojo2.5
    Ballast:
    1100 surf side
    400 goofy side
    500 under floor
    725 IBS
    260 bow floor
    (The more spotters the better)
    Acme1235
  7. #27
    I don't have any of the 13 brackets pictured from my Mojo.
    Here is my 08 LSV with the same brackets they used up through 12 model year.
    New 14 style after they replaced the factory 13s. Honestly you can't see any gell work or anything. Dealer said its almost a direct bolt up. They have to redril the platform mounts under the swim deck. They used RTV to seal the old screw holes.
  8. #28
    Jun 2013
    I don't have any good pics, but I'm pretty sure my '13 OBV brackets look pretty much the same as Mike's pics of his old '08....
    Mike
    2013 Outback V
  9. #29
    Oct 2008
    Central, Arkansas
    New brackets were not introduced until '14, unless you have had a warranty claim done since. '13 brackets were similar to Mike's post except they added the set screw.
  10. #30
    Jul 2013
    Whiteshell, MB
    Thanks, mine seems to be holding in there but we dont get the hours on it that i'd like. I'm going to speak with my dealer and see how big a deal it is...
    2012 Mojo2.5
    Ballast:
    1100 surf side
    400 goofy side
    500 under floor
    725 IBS
    260 bow floor
    Acme1235
