Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
  1. #11
    Jul 2013
    jonesboro IN
    Has this thing back fired or made the little half turn backwards when you shut it off.
    If so the power valve in the carb could be blown.
    2000 Möbius V
    Indmar assault 5.7mpi
    Perfect pass stargazer wake
    Oj 445 will be replaced soon
    1100#on each side of the eng ,800 in ski locker
    almost enough
  2. #12
    Pensacola, FL
    That is probably pretty on target. I would try to change out the gas, replace the fuel filter, and rebuild the carb. If you are not going to do the work yourself, compare the cost of a rebuild (@ $300) to the cost of a new carb (@ $650). If you are quoted a rebuild much higher than that, shop around.
    1997 MasterCraft 205
    2008 Moomba Outback
    1999 MasterCraft Sportstar OB
    1992 MasterCraft 205
    1999 Malibu Response LX
    1987 Marlin Magnum Skier
  3. #13
    Jul 2013
    Windsor ON
    Quote Originally Posted by 86century View Post
    It has sputtered a couple cranks as I shut it off.
    Ya thinking I'm going to go ahead and rebuild the carb and change the plugs and fuel filter. As for the gas, my truck is running low.
  4. #14
    Mar 2003
    s.e. washington state
    As an owner of a 98 Mobius and being a non-mechanic type, I concur that the carb is the culprit. It is easy to run the gas out just by disconnecting the line at the carb, pull the line out and put it into a gas can. Run a jumper from the battery or accessory plug to the positive on the fuel pump and pump away. Have the boat slightly downhill to get all the gas. In the future, I run a couple of gallons of ethanol free gas with Stabil through the system when winterizing and fog the carburator. In the spring, I pump all of the remaining gas and crud out of the tank into a gas can and replace it with fresh gas. Then I use carb cleaner to get rid of the fogging oil. I haven't had a carb problem yet but you have to keep up on it.
    1998 Mobius
    310 HP PCM
  5. #15
    Jul 2013
    Windsor ON
    Thanks guys! This forum is awesome.
    Let you know how it goes.
  6. #16
    May 2013
    I screwed around with rebuilding mine. summer is to short to take it in over and over. A holley 4160 from Jegs is under 6hundy.
  7. #17
    Jul 2013
    Windsor ON
    Ordered the kit from inboardonline.com and just waiting to get this going.
Tags for this Thread
