Results 1 to 10 of 13
Thread: Fly High
    Jul 2012
    Bristol Va
    Default Fly High
    Can anyone give me the code to use at wake makers to buy a ballast sac.
    Thanks, Scott
    Jun 2013
    Oxford, MI
    Dude there's like a thread for that about 5 threads below...welcome to the site?
    Belton, Texas
    No reason to be sassy!! Scott, you can pm wolfeman or mmandley for the code. I'm gonna send us the one I last had and I think it will work but if it doesn't they will hook ya up
    sent from Apple's competitor via tapatalk 4
    2009 Moomba Mobius LSV
    Jul 2012
    Bristol Va
    Thanks very much the code that you sent it worked great. 1100lb bag is on its way and again thanks for YOUR help.
    Arkansas
    Default Re: Fly High
    That was a fun read
    2016 Moomba Mojo
    2006 Supra 24SSV - Traded
    Jun 2013
    Oxford, MI
    Just looks odd when a new member comes on here and the first post is just asking for a discount code! Not trying to be rude...now that you used us, stick around!
    Sent from my piece of crap Galaxy SII that Sprint won't replace...
    Jul 2012
    Bristol Va
    New 1100lb bag now in the boat and my guys love it they are getting a lot more air and one is now landing back flips.
    I moved the 750lb bag to starboard side and put the new 1100lb bag on port for surfing, I fill both bags until the 750lb is full then cut both off and it works great for wakeboarding. Thanks again for the code. And yes this was my first post but I have been reading post for a while now on what you guys were doing with ballast and what seemed to be working best. It's just the first time that I was ready to buy a new bag and that is why I ask for the code so sorry if that rubbed you wrong.
    May 2013
    he's been a member a year longer than you just had to rub it in...
    Jun 2013
    Oxford, MI
    LOL I see that! Wasn't trying to be a jerk, sorry if I also rubbed you wrong Scott!
    I did the same thing as you basically, I put the 1100 in left locker and then 650 in right locker. I can get just about as good of a goofy wake for my 1 friend that surfs goofy out of the 650 on the right as I do with the 1100 on the left.
    What boat do you have and what prop are you running? I did the same thing as you, I filled the 650 up and then the 1100 to be about equivalent, and the boat struggled under that weight. Not nearly enough weight in the front it seemed. The wake was almost too big and steep, I've been running only maybe about 350-400lbs in each locker for wakeboarding and I've had good results with that. I run about 25mph at 70'.
    Jul 2012
    Bristol Va
    Sorry I have not been on much but I have a 2006 Mobius LSV and I put on a new prop from Nettle its a Acme 1847 Propeller 4 Blade and I really like it my son is 6'4" at 245 lbs and he said it really helps with him. I have a bag in the ski locker that I keep full to help with weight in the front and I put people up front also to help. I really like the new bag and thanks for everyone's help.
